Intel® Makers
9874 Discussions
How to format and re install Intel edison
ltami
I have mis-configured the intel edison board in ubuntu system, i could not see any login even a line on terminal,
# screen /dev/ttyUSB0 115200
I have tried with below url there is no output? How to solved this ?
how do you fully recover a board?
And tried another one:
trying to install package-xfstk-downloader-linux.sh
Getting following error:
../../../external-dependencies/min_boost_1_46_1/bin.v2/libs/program_options/libboost_program_options.a(utf8_codecvt_facet.o):(.rodata._ZTVN5boost15program_options6detail18utf8_codecvt_facetE[_ZTVN5boost15program_options6detail18utf8_codecvt_facetE]+0x24): undefined reference to `std::codecvt::do_length(__mbstate_t&, char const*, char const*, unsigned int) const'
collect2: error: ld returned 1 exit status
Pablo_M_Intel
Hi lakshmikandan,
You should flash your Edison board. You can find instructions on how to complete the flash process in the following document /docs/DOC-98643 https://communities.intel.com/docs/DOC-98643. I would suggest you to first try with the Flash Tool Lite, but if this doesn't work there's also an alternative flashing method, you can find a link with further instructions in the document that I provided.
PabloM_Intel
