Intel® Makers
9868 Discussions
How to get Intel PCIe 7260 wifi card supported on Galileo?
BBarm1
I would really like to get the Intel Wireless PCIe 7260 wifi card supported on the Galileo.
It seems that the current build only supports two different type of PCIe wifi cards. The following firmware files are used in the yocto recipes and can be copied over to /lib/firmware
iwlwifi-135-6.ucode
iwlwifi-6000g2a-5
iwlwifi-6000g2b-6
As a long shot I have already tried copying over firmware files for the 7260 for the different linux builds, from the driver web site http://wireless.kernel.org/en/users/Drivers/iwlwifi http://wireless.kernel.org/en/users/Drivers/iwlwifi.
But they do not or have not worked since the current yocto build for Galileo is '3.8.7', and the firmware uCode files have been compiled with newer versions of the kernel. See also discussion at https://communities.intel.com/message/227147# 227147 https://communities.intel.com/message/227147
So I have several options..
1. Upgrade the current linux kernel (3.8.7-yocto-standard) using yocto to 3.10 or above.
So does any one know the roadmap for yocto build for Galileo?
What is the next planned linux version and if so will it be 3.10 or higher?
When is this next planned linux version release?
2. I need to backport the 7260 firmware from the uCode source? If so then I would need to request the uCode source from Intel and then recompile/change the uCode against the current 3.8 release?
Is there anyone in Intel planning to do this?
3. Is there a current Intel wireless driver that has already been written that supports this card, so that I can modify it to work with 3.8 release?
Obviously I would like to go for option # 1, as this would not break any compatibility issues, but it would be really good if we could have more supported PCIe cards that run on the current linux build of Galileo other than just the two PCIe wifi cards ( just realized maybe more with the even older legacy builds ).
Many thanks
Bill
Sergio_A_Intel
Those are all good suggestions, we will pass this feedback to the appropriate team.
Sergio
TFlum
Valued Contributor I
I would also love to see that card supported, preferably with a newer kernel.
I'm using an Intel 512AN card at the moment. All that's needed is to copy over the firmware files and thereafter it's working out of the box.
/Thomas
Sergio_A_Intel
Hi
We are following up on your post and we would like to know if you still need help or if you already have an answer or solution to your question. Remember if someone replied to you with a helpful response you can mark it as correct or helpful answered. We will be waiting your response. Have a great day.
Sergio
TFlum
Hi Sergio,
I would still be interested in a good solution for the PCIe 7260 wifi and bluetooth card. For me the best solution would be a firmware image based on Linux kernel 3.10+ which should have support for that card.
/Thomas
Sergio_A_Intel
Sergio
DFitz4
I am working on this problem now. I wonder has anyone solved this issue yet in the past 18 months!!
I have built new kernel and have the galileo board all working and booting up.
uname -a
Linux quark 3.14.28-ltsi-yocto-standard # 1 Mon Mar 28 17:51:30 AEST 2016 i586 GNU/Linux
i've copied in the latest firmware iwlwifi-7260-ucode files to /lib/firmware directory.
Apparently for my version here it needs the -9 version, so I have that file in the directory.
I have tried looking at dmsg output, lspci, lsmod, etc, but nothing is showing up the PCI card.
lsmod -F firmware iwlwifi gives me list of firmware up to 6000, but not the 7260 firmware in the /lib/firmware folder, however I THINK I HAVE A BIGGER ISSUE, ie:
i can't see any detection on the pci bus that the intel card is detected or in dmsg output.
lspci gives me:
00:00.0 Class 0600: 8086:0958
00:14.0 Class 0805: 8086:08a7
00:14.1 Class 0700: 8086:0936
00:14.2 Class 0c03: 8086:0939
00:14.3 Class 0c03: 8086:0939
00:14.4 Class 0c03: 8086:093a
00:14.5 Class 0700: 8086:0936
00:14.6 Class 0200: 8086:0937
00:14.7 Class 0200: 8086:0937
00:15.0 Class 0c80: 8086:0935
00:15.1 Class 0c80: 8086:0935
00:15.2 Class 0c80: 8086:0934
00:17.0 Class 0604: 8086:11c3
00:17.1 Class 0604: 8086:11c4
00:1f.0 Class 0601: 8086:095e
01:00.0 Class 0280: 8086:08b1
which to me seems like nothing has been detected on the pci bus.
Please help - thanks!
Daniel
Sergio_A_Intel
I noticed you opened a new thread with this same information here . We'll post a reply for you in that thread soon.
Sergio
