Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
How to get stable ad-hoc connection with ch12 or ch13?
Using an Edison with activation of wifi adhoc, and its under the evalution right now.
Though it can be working at the beginning, it became unstable shortly.
Using wifi channel is 12 and 13 as they are reagal channels here in Japan.
Any comment or suggestion would be appreciated.
Our Environment and its procedure is below
Board:Intel Edison Kit for Arduino
OS:Intel Edison Board Firmware Software Release 2.1
[Environment]
  root@edison:~# cat /etc/version
  weekly-159.devkit-2.0
[Procedure]
1.Set country code [ccode=ALL] to [ccode=JP]
2.Set ch13 as an adhoc
ifconfig wlan0 up
-wait for 3 seconds-
wpa_cli -iwlan0 disconnect
wpa_cli -iwlan0 remove_network all
wpa_cli -iwlan0 add_network
wpa_cli -iwlan0 set_network 0 frequency 2472
wpa_cli -iwlan0 set_network 0 mode 1
wpa_cli -iwlan0 set_network 0 ssid \"toroXX\"
wpa_cli -iwlan0 set_network 0 auth_alg OPEN
wpa_cli -iwlan0 set_network 0 key_mgmt NONE
wpa_cli -iwlan0 set_network 0 scan_ssid 1
wpa_cli -iwlan0 set_network 0 wep_key0 31323331323331323331323361
wpa_cli -iwlan0 set_network 0 wep_tx_keyidx 0
wpa_cli -iwlan0 select_network 0
wpa_cli -iwlan0 enable_network 0
wpa_cli -iwlan0 reassociate"
-wait for 3 seconds
ifconfig wlan0 192.168.0.1 netmask 255.255.255.0 up
<span style="color: # 000000; font-family: arial,helvetica,sans-serif; font-size: 10...
Highlighted
Thanks for your cooperation.
I see that the channel 12,13,14 is the channel which edison module won't support.
