Intel® Makers
9881 Discussions
How to install Python 2.7.9+?
JCall9
Hey guys, I have recently been playing around with AWS IoT and I would like to do some test with python on the Edison using paho-mqtt. In order to connect to AWS IoT I need to use ssl.PROTOCOL_TLSv1_2.
Unfortunately that version of TLS is not included in the SSL package below Python Version 2.7.9.
Any suggestions on getting 2.7.9 (or better yet 2.7.11) set up on the edison? I see that currently only Python-Core 2.7.3 is in the opkg repos.
(Running Edison 159.devkit)
Thanks so much!
Jake
JCall9
Ok, managed to get it installed.
Steps:
Downloaded GZipped tarball:
https://www.python.org/downloads/release/python-2711/ https://www.python.org/downloads/release/python-2711/
Extracted
tar xvf Python-2.7.11.tgz
Ran:
./configure
make
make altinstall
Then I ran into some trouble installing paho-mqtt for python 2.7.11
eventually ran:
easy_install2.7 pip
This updated my version of pip to the latest
then I could finally properly run:
python2.7 /usr/bin/pip install paho-mqtt
That finally got me all up to date with python 2.7.11 and paho-mqtt.
Thanks!
Jake
JCall9
Steps:
Extracted
Ran:
./configure
make
make altinstall
eventually ran:
easy_install2.7 pip
Thanks!
Jake
Community Manager
in the moment I do the same on my Intel Galileo.
Do you know how long it takes? (I'm compiling over 24 hours now.)
BR
la_karli
