Intel® Makers
9882 Discussions
How to install batman-adv module
LHeng1
I'm trying to install batman-adv mesh networking module. This is what I tried.
1. Download opkg package from http://repo.opkg.net/edison/repo/edison/kernel-module-batman-adv_3.10.17-r0_edison.ipk repo.
2. Install said .ipk file with opkg (at this point, opkg did not give any error but batman-adv module still doesn't show up on lsmod, so proceeded to install manually)
3. Copy batman-adv.ko from
/lib/modules/3.10.17-yocto-standard/kernel/net/batman-adv/ to /lib/modules/$(uname -r)
4. Run modprobe -f batman-adv
Got "modprobe: ERROR: could not insert 'batman_adv': Exec format error"
modinfo of batman-adv.ko is
filename: /lib/modules/3.10.17-poky-edison+/batman-adv.koversion: 2013.2.0description:B.A.T.M.A.N. advancedauthor: Marek Lindner <</span>mailto:lindner_marek@yahoo.de lindner_marek@yahoo.de>, Simon Wunderlich
rz.tu-chemnitz.de>
license: GPLsrcversion:66711903985B5CAAE0DAF30
depends:
intree: Yvermagic: 3.10.17-yocto-standard SMP preempt mod_unload ATOM
/proc/version/ is Linux version 3.10.17-poky-edison+ (sys_dswci@tlsndgbuild004) (gcc version 4.9.1 (GCC) ) # 1 SMP PREEMPT Fri Jun 19 12:06:40 CEST 2015
How do I proceed?
LHeng1
CMata_Intel PabloM_Intel
Pablo the solution you linked does not solve my problem as I'm intending to compile from external source that is newer than what is included in the Intel package.
I successfully compiled and installed batman-adv by
  1. Following the instructions /thread/60446?start=0&tstart=0 here (make sure you use 32bit Linux) to generate a Debian package containing the Linux headers for 3.10.17 Yocto standard.
  2. And then /thread/62873?start=0&tstart=0 this to install the headers on the Edison.
  3. Download the latest batman-adv source from https://downloads.open-mesh.org/batman/releases/ here and 'make' from Edison itself and then 'make install' to install the module.
Attached is the .deb package and the batman-adv.ko 2015.1 with debug logging enabled.
asss
Valued Contributor II
have you tried to use a command below (without -f argument)?
Commandmodprobe batman-adv
BR,
xbolshe
LHeng1
I was using -f because I wanted it to ignore the version magic. If I omit the -f flag, modprobe gives me this
[30808.013298] batman_adv: version magic '3.10.17-yocto-standard SMP preempt mod_unload ATOM ' should be '3.10.17-poky-edison+ SMP preempt mod_unload ATOM 'modprobe: ERROR: could not insert 'batman_adv': Exec format error
asss
Need to have a driver compiled for your linux image.
You are trying to install a driver compiled for another linux image: http://repo.opkg.net/edison/repo/edison/kernel-vmlinux_3.10.17-r0_edison.ipk http://repo.opkg.net/edison/repo/edison/kernel-vmlinux_3.10.17-r0_edison.ipk
The best way is a creation of own linux image with B.A.T.M.A.N. driver using
a source code available on https://software.intel.com/iot/hardware/edison/downloads IoT - Intel® Edison Board Download | Intel® Developer Zone
BR,
xbolshe
Carlos_M_Intel
Hi myopenid,
Do you have updates on this? Have you tried with xbolshe's suggestions?
Charlie
LHeng1
Pablo_M_Intel
Hi myopenid,
There's a guide that covers this topic thoroughly (even with the same module). Here's the link: https://software.intel.com/en-us/blogs/2015/02/27/intel-edison-adding-kernel-modules-to-yocto-exampl... https://software.intel.com/en-us/blogs/2015/02/27/intel-edison-adding-kernel-modules-to-yocto-exampl.... It's really well explained so you shouldn't have any issues following the steps.
PabloM_Intel
RKirk5
See https://github.com/esialb/yocto-3.10-edison esialb/yocto-3.10-edison · GitHub for an easy way to custimize, build, and install a 3.10.65 yocto kernel with Intel Edison patches
More details here:
LHeng1
