Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9868 Discussions
How to install mariadb or MySQL on Edison?
MGutb
Hello together,
I am new and I want to install a Database mariadb or MySQL on the Edison.
But I don´t know how ? Can someone explain me which packages I need
or is there any tutorial ?
Thx,
Matthias
MGutb
I used this tutorial:http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html Edison Package Repo Configuration Instructions
changed the /etc/opkg/base-feeds.conf file
Then I installed mariadb with:
opkg install mariadb
After that I insert a microSD card and now I try to start the daemon with the parameters:
/usr/bin/mysqld_safe --datadir=/media/sdcard/mariadb/
But I always get after a few seconds at the end the message that:
mysql_safe mysqld prom pid file /var/lib/mysql/mysqld.pid ended
What does it meas ?
Carlos_M_Intel
Hi Matthias,
Did you also run opkg update? Did you have error messages while installing mariadb or it was a successful install?
Let's try with: mysqld --datadir=/home/root
Charlie
