Intel® Makers
9882 Discussions
How to install scipy?
BWill15
New Contributor II
I tried installing scipy (numpy is installed by default). I'm using the eglibc.
1) pip install
root@galileo:/media/card# pip install scipy
Collecting scipy
/usr/lib/python2.7/site-packages/pip/_vendor/requests/packages/urllib3/util/ssl_ .py:315: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may c ause the server to present an incorrect TLS certificate, which can cause validat ion failures. For more information, see https://urllib3.readthedocs.org/en/lates https://urllib3.readthedocs.org/en/lates t/security.html# snimissingwarning.
SNIMissingWarning
/usr/lib/python2.7/site-packages/pip/_vendor/requests/packages/urllib3/util/ssl_ .py:120: InsecurePlatformWarning: A true SSLContext object is not available. Thi s prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see https://urllib3.readthedocs.org/e https://urllib3.readthedocs.org/e n/latest/security.html# insecureplatformwarning.
Downloading scipy-0.17.0.tar.gz (12.4MB)
100% |# | 12.4MB 1.0kB/s
Building wheels for collected packages: scipy
Running setup.py bdist_wheel for scipy ... error
Complete output from command /usr/bin/python -u -c "import setuptools, tokeniz e;__file__='/tmp/pip-build-cULFeC/scipy/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" bdist _wheel -d /tmp/tmpMx25pMpip-wheel- --python-tag cp27:
Traceback (most recent call last):
File "", line 1, in
File "/tmp/pip-build-cULFeC/scipy/setup.py", line 265, in
setup_package()
File "/tmp/pip-build-cULFeC/scipy/setup.py", line 262, in setup_package
setup(**metadata)
File "/usr/lib/python2.7/site-packages/numpy/distutils/core.py", line 143, i n setup
dist = setup(**new_attr)
File "/usr/lib/python2.7/site-packages/numpy/distutils/core.py", line 186, i n setup
return old_setup(**new_attr)
File "/usr/lib/python2.7/distutils/core.py", line 138, in setup
ok = dist.parse_command_line()
File "/usr/lib/python2.7/site-packages/distribute-0.6.32-py2.7.egg/setuptool s/dist.py", line 232, in parse_command_line
result = _Distribution.parse_command_line(self)
File "/usr/lib/python2.7/distutils/dist.py", line 467, in parse_command_line
args = self._parse_command_opts(parser, args)
File "/usr/lib/python2.7/site-packages/distribute-0.6.32-py2.7.egg/setuptool s/dist.py", line 558, in _parse_command_opts
nargs = _Distribution._parse_command_opts(self, parser, args)
File "/usr/lib/python2.7/distutils/dist.py", line 523, in _parse_command_opt s
cmd_class = self.get_command_class(command)
File "/usr/lib/python2.7/site-packages/distribute-0.6.32-py2.7.egg/setuptool s/dist.py", line 362, in get_command_class
ep.require(installer=self.fetch_build_egg)
File "/usr/lib/python2.7/site-packages/distribute-0.6.32-py2.7.egg/pkg_resou rces.py", line 2029, in require
working_set.resolve(self.dist.requires(self.extras),env,installer))
File "/usr/lib/python2.7/site-packages/distribute-0.6.32-py2.7.egg/pkg_resou rces.py", line 2239, in requires
dm = self._dep_map
File "/usr/lib/python2.7/site-packages/distribute-0.6.32-py2.7.egg/pkg_resou rces.py", line 2468, in _dep_map
self.__dep_map = self._compute_dependencies()
File "/usr/lib/python2.7/site-packages/distribute-0.6.32-py2.7.egg/pkg_resou rces.py", line 2501, in _compute_dependencies
common = frozenset(reqs_for_extra(None))
File "/usr/lib/python2.7/site-packages/distribute-0.6.32-py2.7.egg/pkg_resou rces.py", line 2498, in reqs_for_extra
if req.marker_fn(override={'extra':extra}):
File "/usr/lib/python2.7/site-packages/distribute-0.6.32-py2.7.egg/_markerli b/markers.py", line 100, in marker_fn
return eval(compiled_marker, environment)
File "", line 1, in
NameError: name 'sys_platform' is not defined
Failed building wheel for scipy
Running setup.py clean for scipy
Failed to build scipy
Installing collected packages: scipy
Running setup.py install for scipy ... error
Complete output from command /usr/bin/python -u -c "import setuptools, token ize;__file__='/tmp/pip-build-cULFeC/scipy/setup.py';exec(compile(getattr(tokeniz ...
FTinetti
Honored Contributor I
Hi BretchW,
A little bit off-topic (I don't know about scipy installation/usage), but I think Galileo is not focused in compute intensive tasks as those related to BLAS-Fortran. Maybe it's best just to forward HPC/compute intensive tasks to some better computing platform.
Just a suggestion, I don't know the details of your project,
Fernando.
JTurn12
New Contributor II
Hey Brecht,
Did you Try this:
https://github.com/scipy/scipy/blob/master/INSTALL.rst.txt# from-tarballs scipy/INSTALL.rst.txt at master · scipy/scipy · GitHub
You shouldn't need to install "tar" it should already function on your galileo.
try this: from the install docs i posted above: It's kind of slow but..
1. git clone <</span>https://thegitaddress/ https://thegitaddress>
2. cd scipy
3. git clean -xdf
4. python setup.py install --user
I tried this but I didn't have enough space on my galileo.
BWill15
New Contributor II
I will try this as soon as /thread/99579?sr=inbox my partition is larger.
Thank you for your help.
