Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
How to install tesseract-ocr on intel edison
I have to install tesseract-OCR on Intel Edison mini-breakout.
I have followed these steps.
opkg install tesseract
installed properly
opkg install python-setup tools
root@RamishaEdison:/Intel# opkg install python-setup tools
Unknown package 'python-setup'.
Unknown package 'tools'.
Collected errors:
* opkg_install_cmd: Cannot install package python-setup.
* opkg_install_cmd: Cannot install package tools.
opkg install tesseract-ocr
root@RamishaEdison:/Intel# opkg install tesseract-ocr
Unknown package 'tesseract-ocr'.
Collected errors:
* opkg_install_cmd: Cannot install package tesseract-ocr.
I tried running this python program on Intel Edison
import cv2
import cv2.cv as cv
import tesseract
import numpy as np
import pyttsx
import pytesseract
scr = cv2.imread('/Intel/godisgreat.jpg',0)
# cv2.imshow('loaded image', scr)
api = tesseract.TessBaseAPI()
api.Init(".","eng",tesseract.OEM_DEFAULT)
api.SetPageSegMode(tesseract.PSM_AUTO)
image = cv.CreateImageHeader((scr.shape[1],scr.shape[0]), cv.IPL_DEPTH_8U, 1)
cv.SetData(image, scr.tostring(), scr.dtype.itemsize*scr.shape[1])
tesseract.SetCvImage(image,api)
tex=api.GetUTF8Text()
conf=api.MeanTextConf()
g=open('god.txt' , 'w')
g.write(tex)
g.close()
g = open("god.txt")
thegod=g.read()
with open("god.txt", "r") as f:
for line in f:
cleanedLine = line.strip()
if cleanedLine: # is not empty
print(cleanedLine)
cv2.waitKey(0)
cv2.destroyAllWindows()
Getting error is
root@RamishaEdison:/Intel# python memsimage.py
Traceback (most recent call last):
File "memsimage.py", line 9, in
AttributeError: 'module' object has no attribute 'TessBaseAPI'
I don't how to solve this
But this same program running well on windows python shell.
Tags (1)
Community Manager
Hello Ramisha93,
Thanks for reaching out!
The error means that you haven't installed the libraries that the code requires to run. The opkg outputs that you receive say that the packages you are trying to install do not exist on the repo.
I tried to install the required packages, these are the steps I took:
pip install --upgrade pip
pip install pytesseract
pip install opencv-python
pip install pyttsx
opkg install tesseract tesseract-dbg tesseract-dev tesseract-doc
pip install tesseract-ocr
I was able to get rid of some errors but the following stayed:
File "2test.py", line 10, in
NameError: name 'tesseract' is not defined
Where did you get this code? Which packages did you install in Windows in order to make run it?
Let me know.
Pedro M.
Community Manager
Hello Ramisha93,
Do you have any updates about this?
Pedro M.
Community Manager
I collected code by googling. I modified the code according to my requirements of project.
But while running python progrom on windows i it acquires black screen like cmd.exe.
Still same error is following.
Community Manager
Is it possible for your to share the link of the page where you found the code you based your project in?
I'm afraid I don't understand this sentence:
"...But while running python progrom on windows i it acquires black screen like cmd.exe…"
What do you mean by that?
Did you install any python packages in order to run this code on your PC? If so, which ones and how?
Let me know.
Pedro M.
