Trying to follow along in the book by Manoel Ramon, and setting up a dev environment to build a galileo image. According to the book, i should issue a apt-get command to install bitbake. However, when i do that, it returns an error, saying it cant find it. This is ubuntu 14.04. How do i finish installing the set up software needed?
thx
Hello RSanders2016,
I'm not familiar with the book you mention, nevertheless I assume it must have passed a few months since it was published, so it may be outdated. For that reason I would suggest you to follow the official guides to build Galileo's image. In that case I would suggest you to follow Quark's BSP 1.2.1 (http://www.intel.com/content/www/us/en/embedded/products/quark/quark-x1000-bsp-build-sw-rel-user-gui... http://www.intel.com/content/www/us/en/embedded/products/quark/quark-x1000-bsp-build-sw-rel-user-gui...). In that document you will find the instructions on how to build Galileo's image including how to use bitbake.
Let me know if this information helps you.
Peter.
Hello RSanders2016,
Peter.
Peter,
thanks, I think this will do the trick. By the way, the book I was referring to is "Intel Galileo and Intel Galileo Gen 2 API Features and Arduino Projects for Linux Programmers"
thanks again
M Sanders
