Intel® Makers
9867 Discussions
How to make an ad-hoc network
BWill15
New Contributor II
I'm using a Intel® Centrino® Advanced-N 6205 to create an ad-hoc network on a Intel Galileo Gen 2. (Question is at the end)
First list all network related stuff:
ifconfig -a
enp0s20f6 Link encap:Ethernet HWaddr 98:4F:EE:05:29:52
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:1092 (1.0 KiB)
Interrupt:51 Base address:0x8000
enp0s20f6:avahi Link encap:Ethernet HWaddr 98:4F:EE:05:29:52
inet addr:169.254.196.186 Bcast:169.254.255.255 Mask:255.255.0.0
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:720 errors:0 dropped:0 overruns:0 frame:0
TX packets:720 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:52480 (51.2 KiB) TX bytes:52480 (51.2 KiB)
wlp1s0 Link encap:Ethernet HWaddr 44:85:D3:01:B4:07
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
We will need the wlp1s0
Check which card you are using:
lspci -k | grep -A 3 -i "network"
01:00.0 Network controller: Intel Corporation Centrino Advanced-N 6235
Subsystem: Intel Corporation Centrino Advanced-N 6235 AGN
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
My Intel® Centrino® Advanced-N 6205 card was software blocked, so:
rfkill list
0: hci0: bluetooth
Soft blocked: yes
Hard blocked: no
1: phy0: wlan
Soft blocked: yes
Hard blocked: no
rfkill unblock wlan
[ 817.137644] iwlwifi 0000:01:00.0: L1 Disabled; Enabling L0S
root@galileo:~# [ 817.153309] iwlwifi 0000:01:00.0: Radio type=0x1-0x0-0x1
[ 817.612344] iwlwifi 0000:01:00.0: L1 Disabled; Enabling L0S
[ 817.627839] iwlwifi 0000:01:00.0: Radio type=0x1-0x0-0x1
[ 817.905499] IPv6: ADDRCONF(NETDEV_UP): wlp1s0: link is not ready
[ 817.919048] wlp1s0: Trigger new scan to find an IBSS to join
[ 817.983868] iwlwifi 0000:01:00.0: failed to remove IBSS station 00:00:00:00:0 0:00
root@galileo:~# ifconfig wlp1s0 down
root@galileo:~# iwconfig wlp1s0 mode ad-hoc
root@galileo:~# iwconfig wlp1s0 essid GalileoNetwork
root@galileo:~# iwconfig wlp1s0 channel 10
root@galileo:~# ifconfig wlp1s0 192.168.1.2 netmask 255.255.255.0 up
[ 867.448653] iwlwifi 0000:01:00.0: L1 Disabled; Enabling L0S
[ 867.462518] iwlwifi 0000:01:00.0: Radio type=0x1-0x0-0x1
[ 867.749821] IPv6: ADDRCONF(NETDEV_UP): wlp1s0: link is not ready
[ 867.767091] wlp1s0: Trigger new scan to find an IBSS to join
root@galileo:~# [ 872.945639] wlp1s0: Trigger new scan to find an IBSS to join
[ 874.789468] wlp1s0: Creating new IBSS network, BSSID ba:dc:66:9a:d1:68
[ 874.800888] iwlwifi 0000:01:00.0: Unable to find TIM Element in beacon
[ 874.808718] iwlwifi 0000:01:00.0: Unable to find TIM Element in beacon
[ 874.821901] IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
This should be visible.
I made this small script called startup.sh:
# !/bin/sh
rfkill unblock wlan
I made it executable with:
chmod +x startup.sh
The problem is I can't connect to it with Putty.
My static IP addresss is 192.168.1.12 and the gateway is 192.168.1.0. I set the SSH port to 22.
Pablo_M_Intel
Hi BrechtW,
We are now investigating your case, as soon as we have an answer we will post it here.
Pablo
BWill15
New Contributor II
I ran my script and I got this output:
root@galileo:/media/card# /media/card/startup.sh
[ 168.114236] iwlwifi 0000:01:00.0: L1 Disabled; Enabling L0S
[ 168.140364] iwlwifi 0000:01:00.0: Radio type=0x2-0x1-0x0
[ 168.580402] iwlwifi 0000:01:00.0: L1 Disabled; Enabling L0S
[ 168.596029] iwlwifi 0000:01:00.0: Radio type=0x2-0x1-0x0
[ 168.841045] IPv6: ADDRCONF(NETDEV_UP): wlp1s0: link is not ready
[ 168.907676] iwlwifi 0000:01:00.0: failed to remove IBSS station 00:00:00:00:00:00
Error for wireless request "Set Frequency" (8B04) :
SET failed on device wlp1s0 ; Device or resource busy.
Runing it a second time:
[ 293.728291] iwlwifi 0000:01:00.0: L1 Disabled; Enabling L0S
[ 293.744041] iwlwifi 0000:01:00.0: Radio type=0x2-0x1-0x0
[ 294.007921] IPv6: ADDRCONF(NETDEV_UP): wlp1s0: link is not ready
root@galileo:/media/card# [ 299.330347] wlp1s0: Trigger new scan to find an IBSS to join
[ 301.071273] wlp1s0: Creating new IBSS network, BSSID 26:64:0a:44:1f:0d
[ 301.082238] iwlwifi 0000:01:00.0: Unable to find TIM Element in beacon
[ 301.093085] iwlwifi 0000:01:00.0: Unable to find TIM Element in beacon
[ 301.103344] IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
I stil can't connect.
It says Windows can't make connection with this network.
Edit:
te
root@galileo:/media/card# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
169.254.0.0 0.0.0.0 255.255.0.0 U 0 0 0 enp0s20f6
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 wlp1s0
Pablo_M_Intel
Hi BrechtW,
We first try it with the uClibc image, which you can get from here https://software.intel.com/en-us/iot/hardware/galileo/downloads https://software.intel.com/en-us/iot/hardware/galileo/downloads, and we got a successful connection. We then try with the eglibc image, the same you're using right now, and also got a connection. I would suggest you to try with the uClibc image and see if that works. I'm not sure why you're not getting the same results with the IoT image, it would be a good idea to see your results with a different one.
Pablo
BWill15
New Contributor II
On which OS and version did you test this? I just found out an ad hoc network does not work like other wifi-network on Windows 10.
I will get back to you soon.
Edit: It was a windows 10 issue. I thought a ad hoc network was just like any other wifi network to connect to, which isn't true (on Windows 8.1 and 10).
Starting with Windows 8.1, Microsoft reduced support for Adhoc Wifi networks. As a result, Windows 8.1 does not detect or display Adhoc networks in the list of available wireless networks (also known as the "wireless network picker"). Windows 10 behavior is slightly different, as it does detect and display available Adhoc networks, but when attempting to connect, it fails with a "Cannot Connect to Network" error.
I followed https://globalcache.zendesk.com/entries/82172789-FAQ-Windows-8-1-and-Windows-10-AdHoc-network-suppor... this tutorial.
Replace GalileoNetwork with the SSID of your network by using Ctrl-F and finding and replacing each instance. You can then copy and paste each line into the command line window
>netsh wlan show networks
***Go to "Network and Sharing Center"
- Click "Set up a new connection or network"
- Double click "Manually connect to a wireless network"
- Enter the SSID of the adhoc network (as shown by "netsh wlan show networks") into the "Network name" field
- Configure security settings accordingly
- Uncheck "Start this connection automatically" (important)
- Click "Next", then "Close"
***Windows 8.1 command
>netsh wlan set profileparameter GalileoNetwork connectiontype=ibss
***Windows 10 command
>netsh wlan set profileparameter GalileoNetwork connectiontype=ibss connectionmode=manual
>netsh wlan connect GalileoNetwork
***Disconnect
>netsh wlan disconnect GalileoNetwork
***This is to delete the profile
>netsh wlan delete profile GalileoNetwork
Edit2: If you have a USB Wi-Fi dongle laying around, use this to connect. The "normal" Wi-Fi card connects to the Galileo, the dongle to the "regular" internet. This way you still have internet acces with the dongle.
>netsh wlan connect name=GalileoNetwork ssid=GalileoNetwork interface=Wi-Fi
BWill15
New Contributor II
I want to execute the startup.sh at startup. I followed http://stackoverflow.com/questions/12973777/how-to-run-a-shell-script-at-startup this.
I don't think it worked. When I execute it manually I still have to try a few times. How do I make sure the network is setup at startup (maybe try a few times until the link is ready?).
[ 196.637275] iwlwifi 0000:01:00.0: L1 Disabled; Enabling L0S
[ 196.656255] iwlwifi 0000:01:00.0: Radio type=0x2-0x1-0x0
[ 197.100661] iwlwifi 0000:01:00.0: L1 Disabled; Enabling L0S
[ 197.116332] iwlwifi 0000:01:00.0: Radio type=0x2-0x1-0x0
[ 197.361010] IPv6: ADDRCONF(NETDEV_UP): wlp1s0: link is not ready
[ 205.287791] iwlwifi 0000:01:00.0: L1 Disabled; Enabling L0S
[ 205.303407] iwlwifi 0000:01:00.0: Radio type=0x2-0x1-0x0
[ 205.564464] IPv6: ADDRCONF(NETDEV_UP): wlp1s0: link is not ready
root@galileo:/media/card# [ 210.721939] wlp1s0: Trigger new scan to find an IBSS to join
[ 212.597684] wlp1s0: Creating new IBSS network, BSSID 4a:a8:a6:9d:f0:2d
[ 212.611257] iwlwifi 0000:01:00.0: Unable to find TIM Element in beacon
[ 212.619151] iwlwifi 0000:01:00.0: Unable to find TIM Element in beacon
[ 212.632352] IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
FTinetti
Honored Contributor I
Yes. Were you able to make the script to automatically detect it? My suggestion is:
a) Check the script is working correctly, i.e. you do not have to manually try until the network is running, the script does it for you
b) Include the script in the startup process so it executes at boot time.
Fernando.
Pablo_M_Intel
Hi BrechtW,
Did you follow FGT instructions? Were you able to execute the file at startup?
Pablo
