Intel® Makers
9882 Discussions
How to merge edison-v2015.10 patches to mainline u-boot
RAtlu1
New Contributor II
Sirs,
Any idea on how to extract changes from
github.com/01org/edison-u-boot/tree/edison-v2015.10
And merge them into mainline u-boot?
github.com/u-boot/u-boot
I would want to boot the mainline u-boot on edison as it support bootz for x86.
Thanking you
Community Manager
Hello Mosfet,
Could you please let us know why you would like to do this? Also, could you please provide us more details about your project? It would be of much help for us if we could understand this project.
-Peter.
RAtlu1
New Contributor II
Hi Peter,
Where is what we have done. We have generated a custom OSIP.bin file that will then boot to a u-boot as the following.
The u-boot is from here
https://github.com/01org/edison-u-boot/tree/edison-v2015.10 GitHub - 01org/edison-u-boot at edison-v2015.10
The kernel is from here
https://github.com/01org/edison-linux/tree/edison-3.10.98 GitHub - 01org/edison-linux at edison-3.10.98
# Image layout
# | MBR/OSIP Header |
# | u-boot.bin |
# | U-Boot environment |
# | Rootfs (FAT32) |
# | Unused |
# | Unused |
UBOOT OFFSET, 2048
UBOOT ENV MAIN OFFSET 6144
UBOOT ENV REDUNDANT OFFSET, 12288
FAT32 OFFSET, 14336
We then create a single image using DD and burn it edison as follows
xfstk-dldr-solo --gpflags 0x80000007 --osimage output/images/edison.img --fwdnx edison_dnx_fwr.bin --fwimage edison_ifwi-dbg-00.bin --osdnx edison_dnx_osr.bin
And its does boot
However the following are issues.
ISSUE 1 - ZBOOT
=> setenv bootargs console=tty1 console=ttyS2,115200n8
=> load mmc 0 0x100000 bzimage-bit
reading bzimage-bit
6340528 bytes read in 161 ms (37.6 MiB/s)
=> load mmc 0 0x8800000 initramfs-vanilla
reading initramfs-vanilla
9327379 bytes read in 227 ms (39.2 MiB/s)
=> zboot 0x100000 0 0x8100000 0x8100000
Error: Invalid Boot Flag (found 0x0000, expected 0xaa55)
# Kernel loading failed ...
Now zboot is looking for a bootflag in mmc...but my edison-img.vfat is a simple DD written and mkfs.vfat formatted file.
I dont think fdisk can set a boot flag in a virtual file system? I could use gpt from inside edison u-boot to write partition table but then that will destory my vfat that I write to emmc using xfstk.
I did try bypassing by editing it to return 1...however not much help
https://github.com/01org/edison-u-boot/blob/master/arch/x86/lib/zimage.c
if (KERNEL_MAGIC != hdr->boot_flag) {
printf("Error: Invalid Boot Flag "
What does these mean??
Magic signature not found
Invalid Valid Boot Flag
ISSUE 2 - BOOTM
=> setenv bootargs console=ttyMFD2,115200n8
=> load mmc 0 0x100000 uimage
reading uimage
5425120 bytes read in 138 ms (37.5 MiB/s)
=> load mmc 0 0x8100000 initramfs-edison-new
reading initramfs-edison-new
8284799 bytes read in 203 ms (38.9 MiB/s)
=> bootm 0x100000 0x8100000
Wrong Image Format for bootm command
ERROR: can't get kernel image!
I have tried many different conversions using mkimage but bootm simply refuses to recognizes the uimage.
ISSUE 3 - LEFT OVER OPTION IS BOOTZ
However it says => bootz
Your platform's zImage format isn't supported yet!
I realized bootz for x86 is only available in the latest...so I am trying to migrate all the patches from their u-boot git to the latest bleeding u-boot but it doesnt compile as the lastest u-boot has completely changed directory structures etc
ISSUE 3 is the reason I wanted to try Mainline u-boot.
RAtlu1
New Contributor II
The fat partition is a very simple partition containing the Linux kernel and an Initramfs file.
Please help us, this will also pay way for more OSes supporting edison including u-buntu, fedora, arch-linux etc
Please note for Bootz we did the following we edited include/configs/edison.h for raw initrd support
# define CONFIG_CMD_BOOTZ /* bootz zImage support */
# define CONFIG_SUPPORT_RAW_INITRD /* bootz raw initrd support */
However the error is as above...
Community Manager
Hi Mosfet,
Thank you for providing all these details, it helps us a lot. I have one more question, how were you building the image? Did you get the files from https://github.com/01org/edison-u-boot/tree/edison-v2015.10?
Regarding your questions, please let us investigate, we will try to see how we can help you.
I will get back to you as soon as possible.
Peter.
RAtlu1
New Contributor II
git clone that particular branch
make edison_defconfig
make -j4
There is no problem with u-boot. It compiles and boots with our OSIP.
Also understand OSIP has all necessary changes required like correct OFFSETS etc.
This is how we dd
dd if=osip.bin of=output.img
dd if=u-boot.bin of=output.img seek=2056
dd if=u-boot-env.bin of=output.img seek=6144
dd if=u-boot-env.bin of=output.img seek=12288
dd if=rootfs.fat32 of=output.img seek=14336
# Intel's XFSTK tool reads the OSIP header to
# determine where to write the bytes immediately following
# the block, so they need to be removed for the XFSTK tool to work.
dd if=osip.bin of=output_xfstk.img
dd if=output.img of=output_xfstk.img skip=2048 seek=1
This is how we BURN
xfstk-dldr-solo --gpflags 0x80000007 --osimage output_xfstk.img --fwdnx edison_dnx_fwr.bin --fwimage edison_ifwi-dbg-00.bin --osdnx edison_dnx_osr.bin
It does boot (u-boot) however since I use this for preparing rootfs.fat32 I have garbled text
dd if=/dev/zero of=rootfs.fat32 bs=1M count=256
mkfs.vfat -n "alpine" -F 32 -v rootfs.fat32
If i use this as below then it doesnt seem to write the 0xaa55 magic header hence I get the invalid partition flag error
mkfs.vfat rootfs.fat32
RAtlu1
New Contributor II
Are there any changes to upgrade the current u-boot 2015 release to the latest?
RAtlu1
New Contributor II
The problem stems from the fact as to how a mkfs.vfat is used....
GARBLED TEXT
mkfs.vfat -n "edison" -F 32 -v rootfs.fat32
this does set the boot flag however notice how it garbles the text
=> fatls mmc 0
8284735 initramfs-edison
8284799 initramfs-edison-new
5425056 bzimage
3407872 modloop-edison
apks/
553873196 bzimage.backup
▒▒▒▒w/
▒▒7▒▒1▒.▒@6/
2991622641 ▒▒i▒▒▒▒.▒▒r
3728523478 ;▒58▒▒7;.▒q
▒▒巛▒▒▒.▒dy/
1900702730 9_ac'▒▒s.}▒▒
un▒▒w▒▒.t▒▒/
8 file(s), 6 dir(s)
NON-GARBLED TEXT BUT INVALID BOOT FLAG
Plain mkfs formating does NOT produce any such above artifacts however it does not set the boot flag hence resulting in
This does not happen any other boards (even non-x86)....
We are pretty giving up now on edison, we are so near but alas, this is height of ........
Community Manager
Hi Mosfet,
I apologize for the delay in my response.
We have made an extensive research in order to see if we could provide you with further help. Considering that you're modifying the firmware for a very specific use, I'm afraid the assistance we can provide on the debugging is limited.
Sorry we can't be of much help.
-Peter.
