Follow https://software.intel.com/en-us/get-started-galileo-linux-step1 Make a bootable micro SD card, I have 30GB free not use,
I want have more storage in SD Card, what should i do?
I try mount it but when on Yocto, i check "df" command, i recieve :
Filesystem1K-blocksUsed Available Use% Mounted on/dev/root 1668912 1472368110400 94% /devtmpfs 118248 0118248 0% /devtmpfs 118440 0118440 0% /dev/shmtmpfs 1184408552109888 8% /runtmpfs 118440 0118440 0% /sys/fs/cgrouptmpfs 118440 28118412 1% /tmptmpfs 118440 12118428 1% /var/volatile/dev/mmcblk0p150412228748126 5% /media/cardNot have 30 GB???
Thank you,
Thank you,
Hi caothai,
Yes, there is nothing beyond a 1GB partition, so a resize partition is needed. The partition to be resized is the one mounted on /dev/root, which actually is
/dev/mmcblk0p2
so resizing is not possible in the Intel Galileo itself, because the partition is "busy" (mounted on /). Thus, resizing should be made in another OS/environment.
I thought Intel had been documented this issue, but I can't find anything about it beyond custom made images, which is far from overkilling in this case.
HTH,
Fernando.
Thank you,
Hi caothai,
/dev/mmcblk0p2
HTH,
Fernando.
Hi Caothai,
Thanks for reaching out.
FGT is right (Thank you by the way), you have to resize it on another OS/environment.
To solve it, I found this thread that can be helpful for you: https://communities.intel.com/thread/46019 https://communities.intel.com/thread/46019
If you have issues with it try the suggestions here: https://communities.intel.com/message/393112# 393112 https://communities.intel.com/message/393112# 393112
I hope this works for you.
Have a nice day.
Leonardo R.
Thank Fernando and Leonardo R,
I use GParted to rezise /mmcblk0p2, it works :
root@galileo:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 29G 1.5G 27G 6% /
devtmpfs 116M 0 116M 0% /dev
tmpfs 116M 0 116M 0% /dev/shm
tmpfs 116M 8.4M 108M 8% /run
tmpfs 116M 0 116M 0% /sys/fs/cgroup
tmpfs 116M 28K 116M 1% /tmp
tmpfs 116M 12K 116M 1% /var/volatile
/dev/mmcblk0p1 50M 2.3M 47M 5% /media/card
Thank for your help,
Have a nice day,
Thai.
Hi Caothai,
Thank you for letting us know.
It was a pleasure to help you, don't doubt to contact us when you have questions.
Have a nice day.
Leonardo R.
You are welcome,
Fernando.
