Community
cancel
Showing results for
Search instead for
Did you mean:
TWang26
How to program UART serial from Linux on Galileo Gen 2?
Jump to solution
Dear All,
I use Intel Galileo Gen2 and I need 2 UART serials to link to 2 RS232 devices.
Before this, I write a simple Arduino program and utilize UART # 0 in an Arduino sketch, it is connected to shield pins IO0/IO1, it works fine and correctly.
The UART # 1 is connected to shield pins IO2/IO3 works fine as well.
But I try the same setting in Linux environment, and refer http://www.malinov.com/Home/sergey-s-blog/intelgalileo-configuringtheserialportinlinux Sergey's Blog: Configuring the Serial Port in Linux
It doesn't work. Even I google all related information, and try everything I can do. I still have no idea to let it work.
I know Sergey's is Galileo Gen1 so I refer the Gen2's I/O pin configuration from http://www.emutexlabs.com/component/content/article?id=203:getting-started-with-intel-galileo-gen-2 EmutexLab Getting Started with Intel Galileo Gen 2
I change the IO0/IO1 as gpio11/gpio12 and setup the /dev/ttyS0, and it still doesn't work (actually, it can receive data but has problem on sending data via /dev/ttyS0)
Does anyone have any ideas about how to program UART# 0 and UART# 1 serials on Galileo Gen 2 in Linux?
Thank you.
Tevin
Pedro_M_Intel
Hello tevin_wang,
The information you posted on the link above only works on the Galilelo Gen1, because on the Gen2 they changed some of its hardware, so i will post the correct code to write on serial from linux bellow:
cd /sys/class/gpio
echo -n "28" > export
echo -n "32" > export
echo -n "45" > export
cd gpio28
echo -n "out" > direction
echo -n "0" > value
cd gpio32
echo -n "1" > value
cd gpio45
echo -n "1" > value
stty -F /dev/ttyS0 9600 //change to the baud rate you want to use
echo -n "value" > dev/ttyS0 //change value for what you want to write
cat /dev/ttyS0 //read from UART
There is just one detail, whatever you write using echo -n "value" > dev/ttyS0 will be written in ASCII code so make sure you are using the correct ASCII characters.
Peter.
Sergio_A_Intel
Hi tevin_wang,
I will run some tests to try to give you a more accurate response. I will let you know my results.
Sergio
Pedro_M_Intel
Hello tevin_wang,
cd /sys/class/gpio
cd gpio28
echo -n "0" > value
cd gpio32
echo -n "1" > value
cd gpio45
echo -n "1" > value
Peter.
TWang26
Hello, Peter,
It works! I'm glad you solved my problem. Your help is much appreciated.
Tevin
Pedro_M_Intel
Hello tevin_wang,
I'm glad you were able to solve your issue and that I could be of help. If you have any more doubts, don't hesitate to ask.
Peter
DPose
New Contributor II
If you are attempting to access UART0 from C/C++ a better solution is libmraa.so->mraa_uart_init(int). This routine sets up the GPIO to expose the UART for you programajikly. No need for any file operations or calls to external bash scripts etc. It was broken on GEN2 boards until yesterday but has been fixed in the repository by Tom. See /thread/57056 https://communities.intel.com/thread/57056 for more detail.
Dallas
vjhal
I used the following commands:
root@clanton:~# echo -n "4" > /sys/class/gpio/export
root@clanton:~# echo -n "40" > /sys/class/gpio/export
root@clanton:~# echo -n "41" > /sys/class/gpio/export
root@clanton:~# echo -n "out" > /sys/class/gpio/gpio4/direction
root@clanton:~# echo -n "out" > /sys/class/gpio/gpio40/direction
root@clanton:~# echo -n "out" > /sys/class/gpio/gpio41/direction
root@clanton:~# echo -n "strong" > /sys/class/gpio/gpio40/drive
root@clanton:~# echo -n "strong" > /sys/class/gpio/gpio41/drive
root@clanton:~# echo -n "1" > /sys/class/gpio/gpio4/value
root@clanton:~# echo -n "0" > /sys/class/gpio/gpio40/value
root@clanton:~# echo -n "0" > /sys/class/gpio/gpio41/value
cat /dev/ttyS0
These all commands are working fine. I am able to receive data from serial port but when I am trying to send some value to my PC by writing in dev/ttyS0 file, It is not showing on my PC's terminal.
I am using echo -n "value" > dev/ttyS0 command to send data and trying to see it on terminal in my laptop.
TFile
Hi all.
I have Galileo Gen 1. I tried the example above:
cd /sys/class/gpio
cd gpio28
echo -n "0" > value
cd gpio32
echo -n "1" > value
cd gpio45
echo -n "1" > value
echo -n "value" > /dev/ttyS0
cat /dev/ttyS0
but I got:
root@clanton:~# cd /sys/class/gpio
root@clanton:/sys/class/gpio# echo -n "28" > export
cd gpio28
-sh: echo: write error: Device or resource busyecho -n "out" > direction
echo -n "0" > value
root@clanton:/sys/class/gpio# echo -n "32" > export
echo -n "1" > value
root@clanton:/sys/class/gpio# echo -n "45" > export
root@clanton:/sys/class/gpio# cd gpio28
root@clanton:/sys/class/gpio/gpio28# echo -n "out" > direction
root@clanton:/sys/class/gpio/gpio28# echo -n "0" > value
root@clanton:/sys/class/gpio/gpio28# cd gpio32
-sh: cd: gpio32: No such file or directory
root@clanton:/sys/class/gpio/gpio28# echo -n "1" > value
root@clanton:/sys/class/gpio/gpio28# cd gpio45
-sh: cd: gpio45: No such file or directory
root@clanton:/sys/class/gpio/gpio28# stty -F /dev/ttyS0 9600
stty: /dev/ttyS0: Input/output error
root@clanton:/sys/class/gpio/gpio28# echo -n "value" > /dev/ttyS0
-sh: echo: write error: Input/output error
root@clanton:/sys/class/gpio/gpio28# cat /dev/ttyS0
cat: /dev/ttyS0: Input/output error
Do you have any idea ?
Pedro_M_Intel
Hello tsvetan.filev,
The thing is that those instructions will only work on the Galileo Gen 2, these are the instructions for the Gen 1:
Peter.
TFile
Hi Peter.
I gave it a try.
It works when I boot from the board's image.
But when I boot from the image on my SD card (I downloaded the BSP https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23197 Intel® Download Center, added few packages and build my own image) it doesn't.
I got:
root@clanton:~# stty -F /dev/ttyS0 9600
root@clanton:~# echo -n "value" > dev/ttyS0
-sh: dev/ttyS0: No such file or directory
root@clanton:~# cat /dev/ttyS0
root@clanton:~#
Are there any special actions I should take in order to use this UART port.
I tried to kill all galileo (sketch) processes but this didn't help.
I also gave full permissions to /dev/ttyS0 even though I'm already loogged in as root which didn't help as well.
I looked in /var/log/messages but didn't find any error message,
Regards.
Tsvetan.
Pedro_M_Intel
Can you show me what's under /sys/class/gpio and /dev?
Peter.
TFile
Peter,
this is the list:
root@clanton:~# ls /sys/class/gpio
export gpio17 gpio23 gpio29 gpio37 gpio42 gpio48 gpio54 unexport
gpio0 gpio18 gpio24 gpio3 gpio38 gpio43 gpio49 gpio55
gpio1 gpio19 gpio25 gpio30 gpio39 gpio44 gpio50 gpiochip0
gpio14 gpio20 gpio26 gpio31 gpio4 gpio45 gpio51 gpiochip16
gpio15 gpio21 gpio27 gpio32 gpio40 gpio46 gpio52 gpiochip2
gpio16 gpio22 gpio28 gpio36 gpio41 gpio47 gpio53 gpiochip8
root@clanton:~# ls /dev/
block ptyp0 snd tty39 ttyp3
bus ptyp1 spidev1.0 tty4 ttyp4
char ptyp2 stderr tty40 ttyp5
console ptyp3 stdin tty41 ttyp6
core ptyp4 stdout tty42 ttyp7
cpu ptyp5 tty tty43 ttyp8
cpu0 ptyp6 tty0 tty44 ttyp9
cpu_dma_latency ptyp7 tty1 tty45 ttypa
disk ptyp8 tty10 tty46 ttypb
esramtest0 ptyp9 tty11 tty47 ttypc
event0 ptypa tty12 tty48 ttypd
event1 ptypb tty13 tty49 ttype
fd ptypc tty14 tty5 ttypf
full ptypd tty15 tty50 ttyq0
hpet ptype tty16 tty51 ttyq1
i2c-0 ptypf tty17 tty52 ttyq2
iio:device0 ptyq0 tty18 tty53 ttyq3
imrtest0 ptyq1 tty19 tty54 ttyq4
initctl ptyq2 tty2 tty55 ttyq5
input ptyq3 tty20 tty56 ttyq6
kmem ptyq4 tty21 tty57 ttyq7
kmsg ptyq5 tty22 tty58 ttyq8
log ptyq6 tty23 tty59 ttyq9
loop-control ptyq7 tty24 tty6 ttyqa
loop0 ptyq8 tty25 tty60 ttyqb
loop1 ptyq9 tty26 tty61 ttyqc
mem ptyqa tty27 tty62 ttyqd
mmcblk0 ptyqb tty28 tty63 ttyqe
mmcblk0p1 ptyqc tty29 tty7 ttyqf
mqueue ptyqd tty3 tty8 udev_network_queue
msr0 ptyqe tty30 tty9 uio0
mtab ptyqf tty31 ttyGS0 uio1
network_latency ram0 tty32 ttyQRK0 urandom
network_throughput random tty33 ttyQRK1 vcs
null rfkill tty34 ttyS0 vcs1
port root tty35 ttyS1 vcsa
ppp rtc tty36 ttyp0 vcsa1
ptmx rtc0 tty37 ttyp1 zero
pts shm tty38 ttyp2
Pedro_M_Intel
This looks weird, everything seems to be as it should, could your run "cat /sys/kernel/debug/gpio" and show me what it outputs?
You said that it works fine when you use the onboard image but it starts to fail when you use your own image, right? So it looks like it is an issue on that side, when you built your image, did you use "image full" or "image full galileo"?
Also the "-sh: echo: write error: Device or resource busy" messages means they are already exported, you can see then in your last post.
Peter.
TFile
root@clanton:~# cat /sys/kernel/debug/gpio
GPIOs 0-1, platform/sch_gpio.2398, sch_gpio_core:
gpio-0 (sysfs ) out lo
gpio-1 (sysfs ) out lo
GPIOs 2-7, platform/sch_gpio.2398, sch_gpio_resume:
gpio-2 (cy8c9540a-int-s3 ) in hi
gpio-3 (sysfs ) out hi
gpio-4 (sysfs ) out hi
gpio-7 (cy8c9540a-a0 ) in hi
GPIOs 8-15, intel_qrk_gip_gpio:
gpio-8 (SPI_CS ) out hi
gpio-10 (SPI_CS ) out hi
gpio-13 (cy8c9540a-int-s0 ) in hi
gpio-14 (sysfs ) in hi
gpio-15 (sysfs ) in hi
GPIOs 16-55, cy8c9540a, can sleep:
gpio-16 (sysfs ) in hi
gpio-17 (sysfs ) in lo
gpio-18 (sysfs ) in hi
gpio-19 (sysfs ) in lo
gpio-20 (sysfs ) out hi
gpio-21 (sysfs ) out hi
gpio-22 (sysfs ) out hi
gpio-23 (sysfs ) out hi
gpio-24 (sysfs ) in lo
gpio-25 (sysfs ) in hi
gpio-26 (sysfs ) in hi
gpio-27 (sysfs ) in lo
gpio-28 (sysfs ) in lo
gpio-29 (sysfs ) out hi
gpio-30 (sysfs ) out hi
gpio-31 (sysfs ) out hi
gpio-32 (sysfs ) in hi
gpio-36 (sysfs ) out hi
gpio-37 (sysfs ) out hi
gpio-38 (sysfs ) in hi
gpio-39 (sysfs ) out hi
gpio-40 (sysfs ) out lo
gpio-41 (sysfs ) out lo
gpio-42 (sysfs ) out hi
gpio-43 (sysfs ) out hi
gpio-44 (sysfs ) in hi
gpio-45 (sysfs ) in hi
gpio-46 (sysfs ) in hi
gpio-47 (sysfs ) in hi
gpio-48 (sysfs ) in hi
gpio-49 (sysfs ) in hi
gpio-50 (sysfs ) in hi
gpio-51 (sysfs ) in hi
gpio-52 (sysfs ) in hi
gpio-53 (sysfs ) out hi
gpio-54 (sysfs ) out hi
gpio-55 (sysfs ) out hi
Here is what I did:
- Download Board_Support_Package_Sources_for_Intel_Quark_v0.7.5 (from https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23197 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23197)
- untar meta-clanton
- git config --global user.name "my_name"
- git config --global user.email "my_email"
- ./setup.sh
- source poky/oe-init-build-env yocto_build
- modify some files
vi meta-clanton_v1.0.1/meta-clanton-distro/recipes-core/images/image-full.bb
add:
IMAGE_FEATURES += "package-management dev-pkgs"
IMAGE_INSTALL += "apache2 modphp"
IMAGE_INSTALL += "libmpc autoconf automake binutils binutils-symlinks cpp cpp-symlinks gcc gcc-symlinks g++ g++-symlinks gettext make libstdc++ libstdc++-dev file coreutils"
vi meta-clanton_v1.0.1/yocto_build/conf/bblayers.conf
add:
/home/ceco/Documents/galileo/meta-clanton_v1.0.1/meta-oe/meta-webserver \
- bitbake image-full-galileo
- Copy all files from ./tmp/deploy/images/ on SD card
- Boot the image (it boots and works fine) and all file changes are preserved after reboot.
Tsvetan.
Pedro_M_Intel
Everything seems OK, I can see that you added some packages and added a few lines in some files, is that all modified? Did you modify any recipe?
Peter.
TFile
Here is my full howto build:
- git config --global user.name "name"
- git config --global user.email "email"
- ./setup.sh
////////////// Chenge x264_git.bb //////////////
vi meta-clanton_v1.0.1/meta-oe/meta-oe/recipes-multimedia/x264/x264_git.bb
# SRCREV = "1cffe9f406cc54f4759fc9eeb85598fb8cae66c7"
SRCREV = "bfed708c5358a2b4ef65923fb0683cefa9184e6f"
////////////// Change opencv_2.4.3.bb //////////
Source code can be found here: http://www.filewatcher.com/_/?q=OpenCV-2.4.3%2Ctar.bz2 http://www.filewatcher.com/_/?q=OpenCV-2.4.3%2Ctar.bz2
vi meta-clanton_v1.0.1/meta-oe/meta-oe/recipes-support/opencv/opencv_2.4.3.bb
SRC_URI = "ftp://ftp.igh.cnrs.fr/pub/os/linux/0linux/archives_sources/opencv/OpenCV-2.4.3.tar.bz2 ftp://ftp.igh.cnrs.fr/pub/os/linux/0linux/archives_sources/opencv/OpenCV-2.4.3.tar.bz2 \
file://opencv-fix-pkgconfig-generation.patch \
# SRC_URI = "${SOURCEFORGE_MIRROR}/opencvlibrary/opencv-unix/${PV_VER}/OpenCV-${PV}.tar.bz2 \
# file://opencv-fix-pkgconfig-generation.patch \
///////////// Change dmidecode Makefile ///////////
vi meta-clanton_v1.0.1/yocto_build/tmp/work/i586-poky-linux-uclibc/dmidecode/2.10-r2/dmidecode-2.10/Makefile
RM := rm -f
# BSD make provides $MACHINE, but GNU make doesn't
MACHINE ?= $(shell uname -m 2>/dev/null)
# These programs are only useful on x86
PROGRAMS-i386 := biosdecode ownership vpddecode
PROGRAMS-i486 := $(PROGRAMS-i386)
PROGRAMS-i586 := $(PROGRAMS-i386)
PROGRAMS-i686 := $(PROGRAMS-i386)
PROGRAMS-x86_64 := biosdecode ownership vpddecode
PROGRAMS-amd64 := $(PROGRAMS-x86_64)
PROGRAMS := dmidecode $(PROGRAMS-$(MACHINE))
all : $(PROGRAMS)
/////////////// Enable apache2 and modphp ////////////////
and add
and add
vi meta-clanton_v1.0.1/meta-oe/meta-webserver/recipes-php/modphp/modphp5.inc
SRC_URI = "http://pkgs.fedoraproject.org/repo/pkgs/php/php-5.4.14.tar.bz2/cfdc044be2c582991a1fe0967898fa38/php-$ http://pkgs.fedoraproject.org/repo/pkgs/php/php-5.4.14.tar.bz2/cfdc044be2c582991a1fe0967898fa38/php-... \
# Add gcc support #
- Add packages:
vi meta-clanton-distro/recipes-core/images/image-full.bb
IMAGE_ROOTFS_SIZE = "921600"
- Change -ps to -p in tar commands in the following files:
vi poky/meta/classes/staging.bbclass
# not needed !!! vi poky/meta/classes/kernel.bbclass
vi poky/meta/classes/package.bbclass
vi poky/meta/lib/oe/path.py
- bitbake image-full-galileo (I fixed here and there few things)
NOTE: I did the changes in order to be able to build otherwise I get errors.
TFile
Could this be a kernel module related ?
Here is some more information.
Boot messages after SD card boot:
Starting udev
[ 11.416674] mount[1005]: segfault at 0 ip b768992c sp bfd983e8 error ffff0004 in libuClibc-0.9.34-git.so[b7651000+75000]
/etc/rcS.d/S03udev: line 32: 1005 Segmentation fault mount -a -t tmpfs 2> /dev/null
[ 11.612742] udevd[1012]: starting version 182
[ 12.577538] ce4100_spi 0000:00:15.0: enabling device (0000 -> 0002)
[ 12.787138] ce4100_spi 0000:00:15.1: enabling device (0000 -> 0002)
[ 12.923511] intel_qrk_gip 0000:00:15.2: enabling device (0000 -> 0002)
[ 13.022131] platform qrk-gpio-restrict-sc.0: Driver qrk-gpio-restrict-sc requests probe deferral
[ 13.220907] intel_qrk_gpio_probe UIO addr 0x90006000 internal_addr 0xd266e000 size 4096 memtype 1
[ 13.229883] intel_qrk_gip 0000:00:15.2: i2c speed set to 100kHz
[ 13.596479] platform qrk-gpio-restrict-sc.0: Driver qrk-gpio-restrict-sc requests probe deferral
[ 13.880566] sch_gpio_probe UIO port addr 0x1080 size 64 porttype 1
[ 16.975716] spi_master spi0: will run message pump with realtime priority
[ 16.990204] spi_master spi1: will run message pump with realtime priority
[ 17.340337] at24 0-0050: byte_len looks suspicious (no power of 2)!
[ 17.346705] at24 0-0050: 11264 byte at24 EEPROM, writable, 1 bytes/write
[ 17.454149] cy8c9540a 0-0020: dev_id=0x40
[ 17.984004] EFI Variables Facility v0.08 2004-May-17
[ 24.700830] g_serial: Vendor 0x8086 Product 0xbabe
[ 24.705738] g_serial gadget: Gadget Serial v2.4
[ 24.721419] g_serial gadget: g_serial ready
Loaded kernel modules after SD card boot:
root@clanton:~# lsmod
Not tainted
usbhid 23097 0 - Live 0xd275b000
btusb 17950 0 - Live 0xd2827000
bluetooth 188151 1 btusb, Live 0xd27c9000
iwlwifi 73340 0 - Live 0xd2777000
cfg80211 171950 1 iwlwifi, Live 0xd27fc000
rfkill 20724 2 bluetooth,cfg80211, Live 0xd2754000
i2c_dev 13053 0 - Live 0xd274f000
usb_storage 46592 0 - Live 0xd276a000
g_serial 20109 3 - Live 0xd2749000
libcomposite 24059 1 g_serial, Live 0xd2738000
pch_udc 31578 0 - Live 0xd272b000
udc_core 14227 2 libcomposite,pch_udc, Live 0xd26f2000
ipv6 230713 13 - Live 0xd278f000
efivars 22960 0 - Live 0xd2715000
ad7298 12726 0 - Live 0xd26ed000
industrialio_triggered_buffer 12686 1 ad7298, Live 0xd26d3000
kfifo_buf 13032 1 industrialio_triggered_buffer, Live 0xd2654000
industrialio 43160 3 ad7298,industrialio_triggered_buffer,kfifo_buf, Live 0xd26f9000
spidev 13053 0 - Live 0xd26e0000
cy8c9540a 17570 38 - Live 0xd26b4000
at24 12949 0 - Live 0xd26c7000
spi_pxa2xx 21688 0 - Live 0xd26e6000
evdev 17378 0 - Live 0xd26ae000
gpio_sch 17990 6 - Live 0xd267c000
intel_qrk_gip 20101 7 - Live 0xd26da000
uio 14412 4 gpio_sch,intel_qrk_gip, Live 0xd26ce000
8250_pci 31679 0 - Live 0xd26be000
spi_pxa2xx_pci 13049 1 spi_pxa2xx, Live 0xd264f000
mmc_block 26513 2 - Live 0xd2674000
ehci_pci 12656 0 - Live 0xd261f000
ehci_hcd 40376 1 ehci_pci, Live 0xd262b000
ohci_hcd 26434 0 - Live 0xd2664000
sdhci_pci 18191 0 - Live 0xd265e000
sdhci 27440 1 sdhci_pci, Live 0xd2741000
led_class 13282 1 sdhci, Live 0xd271d000
stmmac 48422 0 - Live 0xd2708000
usbcore 140133 6 usbhid,btusb,usb_storage,ehci_pci,ehci_hcd,ohci_hcd, Live 0xd268a000
usb_common 12481 3 libcomposite,udc_core,usbcore, Live 0xd2659000
mmc_core 92969 3 mmc_block,sdhci_pci,sdhci, Live 0xd2637000
Loaded kernel modules after Board boot:
Not tainted
mmc_block 26513 2 - Live 0xd27da000
sdhci_pci 18191 0 - Live 0xd2773000
sdhci 27440 1 sdhci_pci, Live 0xd277b000
mmc_core 92969 3 mmc_block,sdhci_pci,sdhci, Live 0xd278e000
led_class 13282 1 sdhci, Live 0xd2725000
evdev 17378 0 - Live 0xd2704000
usbhid 23097 0 - Live 0xd2715000
btusb 17950 0 - Live 0xd271f000
bluetooth 192247 1 btusb, Live 0xd27aa000
iwlwifi 73340 0 - Live 0xd272f000
cfg80211 171950 1 iwlwifi, Live 0xd2748000
rfkill 20724 2 bluetooth,cfg80211, Live 0xd270e000
ad7298 12726 0 - Live 0xd26ff000
industrialio_triggered_buffer 12686 1 ad7298, Live 0xd26e5000
kfifo_buf 13032 1 industrialio_triggered_buffer, Live 0xd26e0000
industrialio 43160 3 ad7298,industrialio_triggered_buffer,kfifo_buf, Live 0xd26f3000
spi_pxa2xx 21688 0 - Live 0xd26ec000
spi_pxa2xx_pci 13049 1 spi_pxa2xx, Live 0xd26d5000
spidev 13053 0 - Live 0xd26db000
i2c_dev 13053 0 - Live 0xd269e000
at24 12949 0 - Live 0xd26c8000
cy8c9540a 17570 3 - Live 0xd2680000
intel_qrk_gip 20101 4 - Live 0xd26cf000
gpio_sch 17990 2 - Live 0xd267a000
uio 14412 2 intel_qrk_gip,gpio_sch, Live 0xd2652000
usb_storage 46592 0 - Live 0xd2691000
ehci_pci 12656 0 - Live 0xd2637000
ohci_hcd 26434 0 - Live 0xd265e000
ehci_hcd 40376 1 ehci_pci, Live 0xd2686000
usbcore 140133 6 usbhid,btusb,usb_storage,ehci_pci,ohci_hcd,ehci_hcd, Live 0xd26a4000
stmmac 48422 0 - Live 0xd266d000
g_serial 20109 5 - Live 0xd2658000
libcomposite 24059 1 g_serial, Live 0xd2646000
pch_udc 31578 0 - Live 0xd263d000
udc_core 14227 2 libcomposite,pch_udc, Live 0xd262c000
usb_common 12481 3 usbcore,libcomposite,udc_core, Live 0xd261a000
efivars 22960 0 - Live 0xd261f000
Pedro_M_Intel
Yeah, your issue could be caused by the kernel. It seems like the image doesn't have ttySO mapped correctly. What you could try is to create a new image, but I'd suggest you to try using http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/23197/eng/Boar... Board Support Package Sources for Intel Quark v1.0.1.7z. Additionally you can use the patches to upgrade to 1.0.4.
Also, make sure everything you're importing from image-full is in fact added to image-full-galileo.
Peter.
TFile
Hi Peter.
I'm actually already using 1.0.1.7.
I upgraded to 1.0.4 and now all works fine.
STiet
Hi, i have a problem too, how i can fix it?
