In case some people are interested (done on Ubuntu 14.04)
Prerequisite:
git clone git://git.yoctoproject.org/meta-intel-edison
ln -s meta-intel-edison/utils/Makfile.mk Makefile
make setup
Setup:
cd out/linux64
source poky/oe-init-build-env
Files edition:
bitbake -c devshell u-boot
You get a new shell in u-boot sources directories. Modify the files as you need.
Compilation:
bitbake -f -c compile u-boot
Gernerate images:
bitbake -c build u-boot
../../../meta-intel-edison/utils/flash/postBuild.sh .
Note: Don't forget the . at the end of the line above!
Flash:
sudo toFlash/flashall.sh
To simplify and accelerate the flashing, you can comment the lines related to "Flashing boot partition (kernel)" and "Flashing rootfs".
In the end, your Edison board should boot your new U-Boot.
Thanks for this, do you have the instructions how to do this having only the U-Boot Git repository clone? And just out of curiosity what is the version have you got at the end?
Thx for sharing this ...
but can I do this on Windows ... and what if my Edison is not booting at all anymore. i.e. this is my problem
When reverting back to an older image the u-boot of my edison got damaged and now is stopping to boot after the PSH kernel boot
PSH KERNEL VERSION: b0182b2b
WR: 20104000
SCU IPC: 0x800000d0 0xfffce92c
PSH miaHOB version: TNG.B0.VVBD.0000000c
microkernel built 11:24:08 Feb 5 2015
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
So the kernel is not booting anymore and all the scripts that run on the edison won't work anymore
Thx
Hermann
The minimal thing you need to do to flash a new u-boot is:
In u-boot:
=> run do_dfu_alt_info_mmc
=> dfu 0 mmc 0 10 # may need to be done more than once
On host machine:
# dfu-util --verbose --device 0x8087:0x0a99 --alt "u-boot0" --download u-boot.bin
# dfu-util --verbose --device 0x8087:0x0a99 --alt "u-boot-env0" ---download edison-blankcdc.bin
# dfu-util --verbose --device 0x8087:0x0a99 --alt "u-boot-env1" ---download edison-blankcdc.bin -R
`u-boot.bin` and `edison-blankcdc.bin` (and other environments) are found in `build/tmp/deply/images/edison/`. The `--alt` argument is the partition name; these are defined in the u-boot variable `dfu-alt-info`. The `-R` causes a reboot on success.
jpkotta yeah, thanks, I'm playing with U-Boot v2016.11 itself right now, seems I'm about to get it working.
