Community
cancel
Showing results for
Search instead for
Did you mean:
BWill15
New Contributor II
How to run Python file on startup on Intel Galileo
Jump to solution
How do I run a python file on startup on the Intel Galileo.
Tags (1)
Pedro_M_Intel
Hello BrechtW,
On the eglibc image for Galileo you can do it with a system service, I'll give you a brief example on how to do it. You will need three files, your script (test.py), a shell script (test.sh) and your service (test.service).
test.py will be the following simple script:
import time
x = 0
f = open('/home/root/test.txt','w')
while x < 10:
print x
x += 1
f.write(str(x)+"\n")
time.sleep(1)
test.sh will simply start test.py (I had some issues trying to make the service and I was able to solve them this way):
# !/bin/sh
/usr/bin/python /home/root/test.py
test.service will look like this:
# !/bin/sh
[Unit]
Description=test service
[Service]
ExecStart=/home/root/test.sh
Type=idle
[Install]
WantedBy=basic.target
Give test.sh executable right with chmod +x test.sh and store test.service in /lib/systemd/system, test.py and test.sh can be store anywhere but on my example they are stored in /home/root. Once the service file is store in the appropriate directory you can enable the service with systemctl enable test.service. Your script should now start on boot.
Peter.
Pedro_M_Intel
Hello BrechtW,
import time
x = 0
while x < 10:
print x
x += 1
time.sleep(1)
# !/bin/sh
# !/bin/sh
[Unit]
[Service]
Type=idle
[Install]
Peter.
BWill15
New Contributor II
@Intel_Peter How do I set the priority and in which file?
My guess is putting this in test.sh.
nice -n -20 python /my_folder/my_program.py &
Is this correct?
Pedro_M_Intel
What do you mean by priority? On boot? Or would you like to change the process niceness once the OS has finished booting?
Peter.
BWill15
New Contributor II
My program that runs my robot should have the highest priority. I think this is the niceness.
Pedro_M_Intel
Indeed you are correct, a process niceness determines its priority. If you wish to change the process' niceness on boot you can do it by changing the test.sh script (which I posted above). The script should now look like this:
# !/bin/sh
nice -n -20 /usr/bin/python /home/root/test.py
That should change your script niceness on boot.
Peter.
BWill15
New Contributor II
@Intel_Peter I tried your answer but without succes:
galileo login: root
Password:
root@galileo:~# cd /home/root/
root@galileo:~# ls
index.html miniconda3 test.py test.sh
root@galileo:~# cat test.py
import time
x = 0
while x < 10:
print x
x += 1
time.sleep(1)
root@galileo:~# cat test.sh
# !/bin/sh
root@galileo:~# cat /lib/systemd/system/test.service
# ! /bin/sh
[Unit]
[Service]
Type=idle
[Install]
root@galileo:~#
I made it executable and enabled the service.
Edit: It didn't work because one indent wasn't right.
import time
x = 0
while x < 10:
print x
x += 1
time.sleep(1)
FTinetti
Honored Contributor I
I've followed the suggestion at of using the iotkit-agent.service to set a specific IP (I know there is a way of doing it with connman, but I wanted to use ifconfig...) so:
# cd /home/root/
root@galileo:~# cat fixedip
# !/bin/sh
/sbin/ifconfig enp0s20f6:avahi netmask 255.255.0.0 up
# cd /lib/systemd/system
root@galileo:/lib/systemd/system# cat fixedip.service
[Unit]
Description=fixedip
After=network.target
[Service]
ExecStart=/home/root/fixedip
Type=idle
[Install]
WantedBy=multi-user.target
root@galileo:/lib/systemd/system# systemctl enable fixedip.service
Created symlink from /etc/systemd/system/multi-user.target.wants/fixedip.service to
/lib/systemd/system/fixedip.service.
And that's it, the IP is set at startup.
HTH
Fernando.
Community Manager
I have not had to call a shell script to launch a python process on startup. I am able to do it all in python, which seems like a cleaner solution. So here is what I do.
Lets say you have a script "door.py" that monitors a switch. You want it to start on boot up. The file is in /root.
Create a systemd unit file in /lib/systemd/system called doormon.service.
[Unit]
Description=Door Monitor Alet App
[Service]
PIDFile=/var/run/door.pid
WorkingDirectory=/home/root
ExecStart=/usr/bin/python door.py --pid
ExecReload=/bin/kill -s HUP $MAINPID
ExecStop=/bin/kill -s TERM $MAINPID
[Install]
Now notice I am creating a pid file, this lets systemctl stop and reload work.
In your python script use os.getpid() to create a pid file.
fh=open("/var/run/door.pid", "w")
fh.write(str(os.getpid()))
fh.close()
Then use systemctl enable doormon.service
And start your process with systemctl start doormon
Some examples can be seen here:
http://www.instructables.com/id/Intel-Galileo-Garage-Monitor/ http://www.instructables.com/id/Intel-Galileo-Garage-Monitor/
and
https://github.com/joemcmanus/galileoGarageMon https://github.com/joemcmanus/galileoGarageMon
-Joe
