Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
How to run a C++ program on an Edison?
Jump to solution
I want to run https://raw.githubusercontent.com/mevdschee/2048.c/master/2048.c this game on my Edison. It's written in C++ i think. Is there any way to run in on the Edison's linux console? (preferably without using the SDK).
Accepted Solutions
Highlighted
Hello DangerousTim,
You can compile it with the line:
gcc 2048.c -o 2048
And then execute it with:
./2048
Here's a screenshot of the game running on my Edison:
Peter.
Highlighted
Hello DangerousTim,
gcc 2048.c -o 2048
./2048
Peter.
Highlighted
That is indeed a nice game!
Try it out and share your score
Sergio
Highlighted
It's a funny game.
I couldn't a get a score as high as the one gotten by @Intel_Alvarado . CMata_Intel, have you tried it?
Highlighted
Thanks for the quick answer! It works very well on my Edison. I have actually come across many such games for the linux console here, but they use a program called apt-get to download the games. And the Edison doesn't have apt-get. Is there any other way to download, configure and run the game? Thanks in advance
Highlighted
apt-get is a command line tool that handles packages for certain Linux distributions. Edison has opkg according to http://en.wikipedia.org/wiki/Opkg Wikipedia, Open PacKaGe Management is a lightweight package management system based upon ipkg. It is written in C and resembles APT/dpkg in operation. It is intended for use on embedded Linux devices.
In order to get this kinds of games on your Edison you got to have access to the source code so you can compile it on your Edison and run them on it.
Also, you can run a game like https://ttygames.wordpress.com/2013/06/25/yetris/ Yetris compiling the source code with the make command. I ran it using the following commands:
wget https://github.com/alexdantas/yetris/tarball/master https://github.com/alexdantas/yetris/tarball/master --no-check-certificate
tar xvf master
cd alexdantas-yetris-cf3fee6/
make
make run
Or you can simply play https://ttygames.wordpress.com/2013/06/24/frozen-depths/ Frozen Depths after downloading it. You can play it with the commands:
wget http://frozendepths.net/FD105Lin.tar.gz http://frozendepths.net/FD105Lin.tar.gz
tar xvf FD105Lin.tar.gz
cd FD105Lin
./fdepths
Peter.
Highlighted
Thanks so much guys! Downloaded most of the games mentioned on that page on my edison now
I'll come up with an instructble soon...
