Intel® Makers
9872 Discussions
How to run flashall.sh in linux without root or sudo?
SMoy1
I am trying to setup a intel edison flashing station in a production line. I notice linux using flashall.sh expects one to use "sudo" or root. Is it possible to run flashall.sh without root? I like to lock down the flashing station.
My guess is that the root or sudo requirement comes from dfu-util. I came across some udev discussion but not able to come up with a solution to not have root when one uses flashall.sh.
Any help appreciated.
Steven
Pablo_M_Intel
Hi Steven Moy,
I'm not sure if this is possible. I've been doing some research and found the following suggestion:
Sudo chown your_username directory (where "your_username" should be your username and directory the folder that you'll be using)
The other methods that I found involve using root, so I guess that's not an option.
Pablo
VIvan7
New Contributor III
Have you tried to add the user to the dialout group and relogin? I haven't tried it myself.
sudo usermod -a -G dialout $USER
Pablo_M_Intel
Hi Steven,
Were you able to try our suggestions? Did you have any positive results?
Pablo
