Community
cancel
Showing results for
Search instead for
Did you mean:
ROng1
How to send AT command using intel galileo gen 2 with SIM5218E 3G shield
Jump to solution
Hello, I am trying to send AT command using a 3G shield (i.e. SIM5218E from cooking-hacks) for a couple of days already and still no luck. Using Arduino Board, it's okay but with Galileo..it's like walking on a parallel line. Can you help me with this? Thanks
Community Manager
Hi geonyt,
Thank you for contacting us. The shield you're using is included in the Shield Testing Report, which can be found here: http://www.intel.com/content/www/us/en/support/boards-and-kits/000020775.html . If you go to Section 22, you can see a description of the shield, how to power it, libraries needed and a sample sketch to test it.
Please follow this guide to configure the shield. In case you encounter problems, let us know what you've tried so far, along with a detailed description of the error.
We'll be waiting for your response.
-Sergio A
Community Manager
Hi geonyt,
-Sergio A
ROng1
Hello sir Sergio,
Thank you. it works! I'm ready for the next steps.
Can Intel Galileo Gen2 read and write text file other than the SD Card from the board?
FTinetti
Honored Contributor I
Hi geonyt,
The entire filesystem is read/write AFAIK, but I suggest you open another thread explaining exactly what you need/want.
BR,
Fernando.
ROng1
Hello FGT, Yes. Thank you.
Community Manager
You're welcome geonyt, were happy to hear it works. We'll continue to help in the new community thread.
Thanks again for helping out Fernando!
Have a nice day.
-Sergio A
