Community
cancel
Showing results for
Search instead for
Did you mean:
ROng1
How to send SMS to multiple recipients using SIM5218E 3G Shield?
Hello, I am working on another part of my system which is, sending SMS to multiple recipients using AT command. Using AT+CMGS is working but for single recipient. I've tried also using for loop from an array of numbers, still not working. I wonder how to implement such process using AT Comm.
Hope you have some sources or idea about it.
FTinetti
Honored Contributor I
Hi geonyt,
I don't have any device like yours, but maybe I can try to help anyway...
Would you please send the simplest successful code for sending sms?
Fernando.
ROng1
Hello Fernando, below is the working codes for sending single sms.
Serial1.println("AT+CPIN?"); // Is SIM ready to use?
delay(1000);
delay(3000);
Serial.println("Connecting to the network...");
Serial1.println("AT+CGREG?"); // Is device registered?
delay(1000);
Serial1.print("AT+CMGF=1\r"); //Because we want to send the SMS in text mode
delay(1000);
Serial1.println("AT+CMGS=\"your_mobile_number\"");
delay(1000);
Serial.print(c);
delay(1000);
Serial1.println((char)26); //the ASCII code of the ctrl+z is 26 (0x1A)
delay(1000);
Serial1.println();
FTinetti
Hi geonyt,
Thanks for sending details, if you look at the code in section 22 of the Intel document, there is
if (Serial1.available())
Serial.write(Serial1.read());
do you have that code in your sketch? I don't know if that's essential, but I'd use it just in case, mostly in the debug phase.
There are other details at https://www.cooking-hacks.com/documentation/tutorials/3g-gps-shield-arduino-raspberry-pi-tutorial# step5 3G/GPRS shield over Arduino and Raspberry Pi, including arduino code you may test in your environment...
Edit: just in case, another link: http://linksprite.com/wiki/index.php5?title=3G_%2B_GPS_Shield_for_Arduino# Using_3G_module_with_AT_commands 3G + GPS Shield for Arduino - LinkSprite Playgound
HTH,
Fernando.
