Community
cancel
Showing results for
Search instead for
Did you mean:
AEl-K
How to send anything from Edison's Arduino IDE to an android phone via bluetooth?
Jump to solution
Hello all,
I have manged to receive data on my Edison board (on arduino IDE) from an android phone successfully following this tutorial https://software.intel.com/en-us/blogs/2015/05/19/communicate-to-arduino-code-with-your-android-phon... IoT - Communicate to Arduino code with your Android* Phone by Bluetooth Serial Port Profile (SPP) on Intel® Edison | Int… , but now I need to be able to send even a string from my Edison (via arduino IDE) back to the android phone via Bluetooth, I have searched a lot but can't find an answer.
Thanks in advance
Pablo_M_Intel
Hi A.Kerdany,
As you say, there's a lot of information on sending data from Android to Edison, but there's not so much the other way around.
I would suggest you to check this thread /thread/57003 https://communities.intel.com/thread/57003. Peter recommends some links that will get you started. However, it would be easier if you use a different approach like TCP/IP instead of Bluetooth profiles.
Pablo
Pablo_M_Intel
Hi A.Kerdany,
Pablo
