Community
cancel
Showing results for
Search instead for
Did you mean:
SDeka1
How to share internet from a laptop with Intel Galileo Gen2 board ?
 Hi all. I am Sukanya. I have been using Intel galileo Gen2 board for a couple of months.I have connected the board to my laptop via ethernet using putty. I want to share the internet connectivity from the laptop to board. I have run this command : ifconfig enp0s20f6 down in linux shell of the board but the board becomes unresponsive after this. I am unable to figure out anything. Please help.
Luis_at_Intel
Hi @SDeka1​ ,
Thanks for reaching out. I am not sure why the board would become unresponsive after trying that command, it could be that somehow its interfering with the serial connection. I found this blog somebody shared on how to bridge and share your Windows internet network to the Galileo board, you can find the blog here https://www.c-sharpcorner.com/UploadFile/f55fd9/sharing-pc-network-with-intel-galileo-on-windows.
Hopefully you are using Windows so that you can give this a try, if that is not the case please let me know which OS you are using and I will try to investigate further. Hope you find this helpful.
@Luis_at_Intel​
SDeka1
Thank you for replying. I am using Windows on my laptop and Linux Yocto Standard for Intel Galileo Gen 2 board.
But in the blog it is written that the board needs to be booted with windows os but my board is booted with linux os. Will it be a problem to adopt this method?
SDeka1
Unfortunately the steps illustrated did not work in my board.
Aroop_B_Intel
Hi SDeka1,
The correct command that you should enter into the linux terminal is
ifconfig <Hostname> down
Can you confirm that your hostname is "enp0s20f6"?
To do so you should enter this into your linux terminal:
ifconfig
This will list multiple network interfaces and their details.
Your hostname should have the attribute: "Link encap:Ethernet"
Aroop
SDeka1
Thanks a lot for answering @Aroop_at_Intel. That issue has been solved. But I ran into a new problem.
I am trying to install php in the board by using this command opkg install modphp. On executing this command, it shows an ouput that no such module exists.
I want to know whether there is any other method to download and install php in the board. Please help.
Aroop_B_Intel
Hello SDeka1,
I would suggest looking at this thread to help you install php.
https://forums.intel.com/s/feed/0D50P0000490Ir9SAE?language=en_US
Aroop
