Intel® Makers
9881 Discussions
How to ssh over wifi?
MSidd5
I am a total newbie and trying to ssh over wifi but i don't know how to do it can somebody please tell me step by step to how to ssh over wifi?
Diego_V_Intel
Hello MASiddiqui,
In order to get access to the Edison through SSH you have to set up the Edison's Wi-Fi first, and assign a name and a password to your module. This can be done by running the command configure_edison --setup.
If you haven't used your Edison before, then I recommend you to check the getting started guide: https://software.intel.com/en-us/iot/library/edison-getting-started IoT - Intel® Edison Board Get Started Guide | Intel® Developer Zone. It will guide you through the first steps of configuring your Edison.
Diego.
Diego_V_Intel
Hello MASiddiqui,
Diego.
MSidd5
I've already done that but now i want to know how do i ssh over wifi
Diego_V_Intel
Hello MASiddiqui,
If the Edison is already configured, then you could SSH to it with the PuTTY software. I recommend you to download it and try it. Once you open it you will see an option for SSH (check screenshot below). You will need to type the Edison's IP address. The IP address can be checked by running the following command in the Edison's console: configure_edison --showWiFiIP
Make sure the Edison and your PC are connected to the same network.
Diego.
MSidd5
Thank you but i figured it out and by the way i am using OS X so there is no putty, i used terminal to do ssh to my edison board over wifi.
FBuit
Innovator
Hi , you have to put this command in a terminal you have to be connected in the same wi-fi where you have connected your Edison Board
ssh root@yourEdisonIP
if it doesn´t work let me now.
