Intel® Makers
9868 Discussions
How to transfer data using Uart in Galileo Gen 2
CT2
I tried the below coding to transfer data from Intel Galileo Gen 2 to uart. But some error comes after building in Eclipse
# include
# include
# include
# include"mraa/uart.h"
# define EXIT_SUCCESS 1
int main(int argc, char** argv)
char tx_data[]="hello";
char rx_data[]="";
mraa_uart_context uart1;
uart1=mraa_uart_init(0);
mraa_uart_set_baudrate(uart1,9600);
//mraa_uart_set_mode(uart1,8,MRAA_UART_PARITY_ONE,1);
mraa_uart_write(uart1 ,tx_data, sizeof(tx_data));
//printf("Tx_Data=%c",tx_data);
//fprintf(stdout, "Gpio is %d\n",mraa_uart_write(uart1 ,tx_data, 4));
mraa_uart_read(uart1 ,rx_data, sizeof(rx_data));
//printf("Rx_Data=%c",rx_data);
//mraa_uart_stop(uart1);
//mraa_deinit();
return EXIT_SUCCESS ;
after building time the following error coming.
In file included from ..\src\tx.c:4:0:
C:\iotdk-ide-win\devkit-x86\sysroots\i586-poky-linux/usr/include/mraa/uart.h:47:75: error: unknown type name 'mraa_uart_parity_t'
mraa_result_t mraa_uart_set_mode(mraa_uart_context dev, int bytesize, mraa_uart_parity_t parity, int stopbits);
Brendan_L_Intel
update mraa & your ide, should sort you out.
CT2
Hi arfoll,
Can you share to me about updated Eclipse IDE and mraa libraries link.
Brendan_L_Intel
You'll want the latest IDE and the latest Edison image. You can browse the download dir too:
https://software.intel.com/en-us/iot/hardware/edison/downloads IoT - Intel® Edison Board Download | Intel® Developer Zone
The IDE does let you update mraa but latest image will be on mraa 0.8.1 already so that's your best bet.
Pedro_M_Intel
Hello china007,
Have you already tried with the mraa example found in https://github.com/intel-iot-devkit/mraa/blob/master/examples/uart.c mraa/uart.c at master · intel-iot-devkit/mraa · GitHub?
If you still run into issues, I'd suggest you to compile it directly on your board. It is very simple, just follow these steps:
1. Create the file where your code will be stored with "vi YOUR_FILE_NAME.c" and paste your code.
2. Compile the code and create an executable file with "gcc YOUR_FILE_NAME.c -o OUTPUT_FILE_NAME -lmraa"
3. Then run the code with ./OUTPUT_FILE_NAME
Peter.
