Hi
I've tried to update NodeJS on my Intel Edison, but without luck.
What's the best way to update to the latest version of nodejs?
Thanks in advance
- Tags:
- Intel® Node Manager
Hello Terkel,
If you use http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html AlexT's repo you will be able to update to the version 0.12.7 of Node.JS. However, /thread/97076?start=0&tstart=0 this version is known to not be 100% compatible with mraa.
This version is now a little out of date. I was able to compile from source a previous version in /message/314636# 314636 Re: [HELP] I'm having trouble updating to node 0.12.5. You can check how it's done and try to compile a newer version.
Peter.
Hello Terkel,
Peter.
