I would like to upgrade GCC compliter from 4.8 to 4.9, however I cannot search for the command to upgrade this.
My gcc version is shown as per below:
root@edison:~# gcc --version
gcc (GCC) 4.8.2
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
May I know the command line in order to upgrade GCC complier from 4.8 to 4.9?
Thank you.
Hello cnvery,
Version 4.9.1 of GCC can be downloaded from AlexT's repo. In case you haven't set up the repo yet, go to http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html to learn how to do it. Once the repo has been set, type the following commands:
opkg update
opkg install gcc
That should install GCC version 4.9.1. Let me know if it works.
Peter.
Hello cnvery,
opkg update
opkg install gcc
Peter.
Hi Peter,
Thanks for the reply.
It works perfectly!
The GCC version now is 4.9 version.
gcc (GCC) 4.9.1
Copyright (C) 2014 Free Software Foundation, Inc.
Hi Peter,
May I know is there any way to restore back the GCC complier from 4.9.1 to 4.8.2?
When using GCC for 4.8.2 for compiling of Azure IoT SDK, it shows:
-- The C compiler identification is GNU 4.8.2
-- The CXX compiler identification is GNU 4.8.2
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- broken
When using GCC for 4.9.1 for compiling of Azure IoT SDK, it shows:
-- The C compiler identification is GNU 4.9.1
-- The CXX compiler identification is unknown
-- Check for working C compiler: /usr/bin/cc -- broken
Although gcc --version showed upgraded gcc (GCC) 4.9.1, but g++ --version showed g++ (GCC) 4.8.2.
This means gcc and g++ version are different.
Thank you.
Hi cnvery,
In fact if you use the latest version of the image both GCC and G++ have been updated to version 4.9.1. However if you still would like to uninstall it, you can do it with the following command:
opkg remove gcc --force-removal-of-dependent-packages
Peter.
Hi Peter,
The mentioned command line will remove only GCC 4.9.1 itself (= restore back to 4.8.2) or remove whole GCC complier?
Thank you.
The line will remove the GCC compiler but you can install the version 4.8.2 if run the following lines:
echo "src intel-iotdk http://iotdk.intel.com/repos/1.1/iotdk/i586/ http://iotdk.intel.com/repos/1.1/iotdk/i586/" >> /etc/opkg/iotdk.conf
opkg update
opkg install gcc
Peter.
Hi Peter,
I have tried it out.
It still install back GCC 4.9.1.
After installation, "gcc --version" command showed "-sh: gcc: command not found".
Any idea on this?
Thank you.
I'm sorry, it was my mistake, the command I posted above:
Should have been:
echo "src intel-iotdk http://iotdk.intel.com/repos/1.1/iotdk/i586/ http://iotdk.intel.com/repos/1.1/iotdk/i586/" > /etc/opkg/iotdk.conf
Try it and let me know if this time it works, I'll be waiting for your reply.
Peter.
Hi Peter,
The command line does not change the version it installed.
It still install back GCC 4.9.1 and "gcc --version" command showed "-sh: gcc: command not found" after installation.
Thank you.
If you keep receiving the message "-sh: gcc: command not found", I'd suggest you to reflash the Edison. Then you can follow these steps to install the 4.8.2 version of GCC manually (without using the repo):
1. opkg remove gcc --force-removal-of-dependent-packages
2. wget http://iotdk.intel.com/repos/1.1/iotdk/i586/gcc_4.8.2-r0_i586.ipk http://iotdk.intel.com/repos/1.1/iotdk/i586/gcc_4.8.2-r0_i586.ipk
3. opkg install gcc_4.8.2-r0_i586.ipk
That should install version 4.8.2 on your board. Let me know if it works.
Peter.
