Intel® Makers
9874 Discussions
How to upload firmware on D2000 without ISSM?
AZimi
New Contributor II
Hello!
I need to upload/erase firmware without ISSM, and do that automatically (without manual commands input in a command promt).
Maybe you know some ready front-end software for that?
I'm trying to write a software by Qt, which make a telnet connection to an openOCD. Am I need to create gdb session, or I can upload firmware with openocd only?
Community Manager
You can find the firmware flashing instructions using CLI (and without using Intel System Studio for Microcontrollers) here:
https://github.com/quark-mcu/qmsi# flashing GitHub - quark-mcu/qmsi: Quark MCUs HAL
I am not aware of a GUI frontend, except of the Intel System Studio for Microcontrollers.
Another option would be using the DFU / firmware manager mechanism and a serial port. It is a single CLI command. Also there is a make target for that ("make flash" in qmsi/examples/app.mk).
AZimi
New Contributor II
Hi!
Yes, I know about this CLI instructions, but there's using gdb for upload firmware, and i'm asking about using openocd only for that.
In this case I need to upload ROM at first with ISSM, but I want to make that via standalone application too.
AZimi
New Contributor II
Thanks you all. Issue is solved.
