Intel® Makers
9872 Discussions
How to use I2C to control PMIC
DDam
Hi all
In section 3.5 of this document http://download.intel.com/support/edison/sb/edisonmodule_hg_331189004.pdf http://download.intel.com/support/edison/sb/edisonmodule_hg_331189004.pdf, PMIC can be controlled and programmed using I2C interface. But I don't know how to do it ? Anyone can help ?
Thank you very much
Community Manager
Hello AaronShea,
What the hardware guide mentions is only that Edison's CPU controls the PMIC through one of its I2C interfaces. As you may know Edison's CPU has more than two I2Cs, however, only two of them are available for the user (just one if using the Arduino board). The PMIC is controlled through one of these interfaces that are not available for the user.
-Peter.
Community Manager
Hello AaronShea,
-Peter.
DDam
