Intel® Makers
9872 Discussions
How to use hcsr04 with mraa and upm in python
BWill15
New Contributor II
I want to use the hc-sr04 with mraa and upm in python. There are no ultrasonic https://github.com/intel-iot-devkit/upm/tree/master/examples/python python examples provided on Github.
I found this source code for ultrasonic sensors in the upm Github repository: https://github.com/intel-iot-devkit/upm/tree/5a5637a4319e0cfdf50e6efac09eb106bd80131d/src/groveultra... groveultrasonic and https://github.com/intel-iot-devkit/upm/tree/5a5637a4319e0cfdf50e6efac09eb106bd80131d/src/hcsr04 hcsr04.
Can someone provide some example code for the Intel Galileo Gen 2?
Edit: maybe this helps:
http://iotdk.intel.com/docs/master/upm/python/pyupm_hcsr04.html pyupm_hcsr04 module — upm v0.5.1-4-g1aa445b documentation
http://iotdk.intel.com/docs/master/upm/python/pyupm_groveultrasonic.html?highlight=ultrasonic# module-pyupm_groveultrasonic pyupm_groveultrasonic module — upm v0.5.1-4-g1aa445b documentation
https://software.intel.com/en-us/iot/hardware/sensors/hcsr04-ultrasonic-sensor IoT - HC-SR04 Ultrasonic Sensor | Intel® Developer Zone
Community Manager
I found no sample codes of the hc-sr04 sensor for Python. Take a look at this thread /message/340756# 340756 https://communities.intel.com/message/340756# 340756 . Another user has already asked how to use this sensor with Python. Take a look at the suggestion and threads posted.
Let us know your results.
Sergio
BWill15
New Contributor II
I didn't have good luck with the links you mentioned.
I found this code and modified it slightly:
# http://stackoverflow.com/questions/32300000/galileo-and-ultrasonic-error-when-distance-less-than-4cm http://stackoverflow.com/questions/32300000/galileo-and-ultrasonic-error-when-distance-less-than-4cm
import mraa
import time
trig = mraa.Gpio(0)
echo = mraa.Gpio(1)
trig.dir(mraa.DIR_OUT)
echo.dir(mraa.DIR_IN)
def distance(measure='cm'):
trig.write(0)
time.sleep(0.002)
trig.write(1)
time.sleep(0.00001)
trig.write(0)
sig = None
nosig = None
et = None
while echo.read() == 0:
nosig = time.time()
while echo.read() == 1:
sig = time.time()
if sig == None or nosig == None:
return 0
# et = Elapsed Time
et = sig - nosig
if measure == 'cm':
distance = et * 17150
elif measure == 'in':
distance = et / 0.000148
else:
print('improper choice of measurement!!')
distance = None
return distance
while True:
t1 = time.time()
print(distance('cm'))
print time.time() - t1
Is it possible to do it with an interrupt? Now I i'm doing nothing until the echo is received.
BWill15
New Contributor II
I tried this. The code works, but the destance isn't right.
import mraa
import time
import sys
class ElapsedTime:
begintime = 0.0
endtime = 0.0
elatime = 0.0
echoPin = 3
echo = mraa.Gpio(echoPin)
trig = mraa.Gpio(2)
et = ElapsedTime()
# inside a python interrupt you cannot use 'basic' types so you'll need to use
# objects
def mraaISR(gpio):
et.endtime = time.time()
et.elatime = et.endtime - et.begintime
print("Interrupt detected")
# print et.endtime - et.begintime
global et
try:
print("Starting ISR for pin " + repr(echoPin))
# https://github.com/intel-iot-devkit/mraa/blob/master/examples/python/hello_isr.py https://github.com/intel-iot-devkit/mraa/blob/master/examples/python/hello_isr.py
echo.isr(mraa.EDGE_RISING, mraaISR, echo)
et.begintime = time.time()
trig.write(0)
time.sleep(0.002)
trig.write(1)
time.sleep(0.00001)
trig.write(0)
time.sleep(2)
echo.isrExit()
except ValueError as e:
print(e)
if measure == 'cm':
distance = et.elatime * 17150
distance = et.elatime / 0.000148
else:
print('Improper choice of measurement!!')
distance = None
return distance
while True:
time.sleep(0.5)
Community Manager
You mean to say that the distance values are incorrect even though the code compiles? I noticed in your last thread you modified the last while statement. Make sure this doesn't change the expected results. Do you receive incorrect values with both "cm" and "in"?
According to the datasheet the formulas are uS / 58 = centimeters or uS / 148 =inch or the range = high level time * velocity (340M/S) / 2. Also the module cannot measure distances lower to 2cm. Make sure these formulas are correct and that you have the latest mraa version available.
Sergio
BWill15
New Contributor II
I only use the metric system. The inches are a result of http://stackoverflow.com/questions/32300000/galileo-and-ultrasonic-error-when-distance-less-than-4cm the code I based my code on.
The change in the wile statement didn't affect the results. It now measures only every half a second instead of as fast as possible.
I tested the code without the interrupt and it is accurate. I checked it with a ruler of 30 cm. I think these conversion could also be used in the interrupt method. Only the way of measuring the time between the trigger and the echo is diferent. The conversion remains the same.
us/58
= s/0.000058
= s* (1/0.000058)
= s * (17241)
+/-=s * 17150
I think the conversion isn't the problem.
This is my working code without an interrupt.
import mraa
import time
trig = mraa.Gpio(2)
echo = mraa.Gpio(3)
def distanceUS():
tZero = time.time()
# reading sensor in Python takes about 6 ms (US = Utrasonic Sensor)
# http://playground.arduino.cc/Main/UltrasonicSensor http://playground.arduino.cc/Main/UltrasonicSensor
trig.write(0)
time.sleep(0.000004) # in Arduino 2 microseconds, double this value to be sure
trig.write(1)
time.sleep(0.00001) # in Arduino 5 microseconds, double this value to be sure
trig.write(0)
sig = None
nosig = None
etUS = None
nosig = time.time()
sig = time.time()
return 0
# et = Elapsed Time
etUS = sig - nosig
distance = etUS * 17150
return distance
while True:
t1 = time.time()
print(distanceUS())
PS: the "US" stands for Utrasonic Sensor
Community Manager
This issue might be related to the speed of the pins of the sensor. Can you connect a logic analyzer to compare the pulse of the data sent by the sensor to the values set in the code?
If the code is correct, then the issue is likely the reading of the signal. You can connect a logic analyzer or an oscilloscope to compare these values.
Sergio
Community Manager
Were you able to resolve this issue and use the hc-sr04?
Sergio
BWill15
New Contributor II
I didn't try it yet. For now I'm using the polling method instead of the interrupt based method.
Community Manager
Sergio
BWill15
New Contributor II
This method uses polling with a time-out:
Change the @timeout(0.020) based on your application. Maximal recommended value is 0.035.
@timeout(0.020)
timeout.py
from functools import wraps
import errno
import os
import signal
# http://stackoverflow.com/questions/11901328/how-to-timeout-function-in-python-timeout-less-than-a-se... http://stackoverflow.com/questions/11901328/how-to-timeout-function-in-python-timeout-less-than-a-se...
class TimeoutError(Exception):
pass
def timeout(seconds=10, error_message=os.strerror(errno.ETIME)):
def decorator(func):
def _handle_timeout(signum, frame):
raise TimeoutError(error_message)
def wrapper(*args, **kwargs):
signal.signal(signal.SIGALRM, _handle_timeout)
signal.setitimer(signal.ITIMER_REAL,seconds) # used timer instead of alarm
try:
result = func(*args, **kwargs)
finally:
signal.alarm(0)
return result
return wraps(func)(wrapper)
return decorator
hcsr04.py
import mraa
import time
from timeout import timeout
trig = mraa.Gpio(3)
echo = mraa.Gpio(4)
@timeout(0.020)
def distanceUS():
tZero = time.time()
trig.write(0)
trig.write(1)
trig.write(0)
sig = None
nosig = None
etUS = None
nosig = time.time()
sig = time.time()
return 0
# et = Elapsed Time
etUS = sig - nosig
return distance
while True:
try:
print distanceUS()
except Exception, e:
# print 'time out!'
continue
