Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
How to use i2c block?
Jump to solution
Hi guys, i need help on how to connect the grove lcd rgb backlight v 2.0 to sparkfun i2c block? I want the value to be displayed on the lcd using node.js but im not sure how does the connection work and what is the code for node.js? Pls help me
Accepted Solutions
Highlighted
Community Manager
Hi Kat,
For connection information you can check the Sparkfun tutorial on using the I2C block, here's the link https://learn.sparkfun.com/tutorials/sparkfun-blocks-for-intel-edison---i2c-breakout-block?_ga=1.740... https://learn.sparkfun.com/tutorials/sparkfun-blocks-for-intel-edison---i2c-breakout-block?_ga=1.740.... There you'll find detailed instructions, including recognizing the device in console. Regarding the code, we don't have any code for controlling an LCD but you can check the Community and you'll probably find some useful examples.
-Pablo
Highlighted
Community Manager
Hi Kat,
-Pablo
