Intel® Makers
9882 Discussions
Humidity Sensor !!!!
ahij
which humidity sensor is compitable for intel galileo board? please any Info ???? Help please
RGeno1
I think that there are probably many humidity sensors that work well with the Galileo. I have successfully interfaced a Honeywell HIH-5030 and it is relatively simple. The easiest solution, in my opinion, is to use one with a voltage output (as is the case with the HIH-5030). In this fashion, you basically are simply hooking it up to an A2D pin and, along with some temperature correction, that's pretty much the whole thing. I have been thinking of posting the 'experience' with code, but will likely not get to it for a while.
Diego_V_Intel
Hi ahmadto,
The Intel® Galileo Board has I2C, SPI and UART interfaces so you can use devices with this kind of interfaces to communicate them with the board. Also you have the option to use the analog pins (ADC) to connect analog sensors with voltage output, just be careful with the voltage limits of the board.
Let us know if this information was helpful for you. Have a nice day!
Diego.
DGong
I have a project of Temperature and humidity sensor (using IC - not capacitive / thermistor sensor) - which come in form of a probe and a corresponding Arduino shield.
https://www.kickstarter.com/projects/1567547471/iot-temperature-and-humidity-probe-shield-for-ardu https://www.kickstarter.com/projects/1567547471/iot-temperature-and-humidity-probe-shield-for-ardu
In fact I want to test the compatibility of my project with Intel Galileo - which supposedly can accept Arduino compatible shields.
Is there anyway I can check with you or anyone to advise ?
Forum Admin / Intel - pardon for pasting the link below - this is not meant to be a commercial - genuinely I want to work with Intel / Galileo community to sort out this compatibility test.
Please point / show the way - Thanks.
Diego_V_Intel
Hi dragon_intelligence,
It is true that the Galileo board is compatible with the Arduino Shields but there is some shields that may not work correctly. In order to know what are the tested shields at this moment please check this document: /servlet/JiveServlet/previewBody/22995-102-1-26777/GalileoShieldTestReport_330937_001.pdf Shield Testing Report.
The document has the official test reports of some shields but this doesn't mean that another shield will not work. There are new shields almost each week so I encourage you to test your shield and share the results with the community. Have a nice day!
Diego.
DGong
Hi DiegoV
Thanks for your response, we would like to test the compatibility for sure - the issue is we don't have Intel's Galileo system - and not sure we can justifying to the boss for buying it with the main purpose being to test the compatibility.
Is there anyway Intel can help us achieve this - this would for sure help Intel's proliferation in the Maker / DIY community.
MIvan4
Hello there,
I hope the author of this thread doesn't mind if I re-open this discussion after some time....
I'm looking for any humidity ( doesn't need to have humidity & temp) sensor that I can connect directly into the Seeedstudio Grove shield (that is attached to the intel edison arduino board). I've already read that the DHT11 / DHT22 has some issues and only a workaround exists (since I admit I'm not really technically-skilled to do any HW engineering / soldering / DYI work etc.,as I'm more into SW side of thing, this is not the right solution for me...)
I've read similar thread that suggested buying one of these:
http://sensing.honeywell.com/honeywell-sensing-hih4030-4031%20series-product-sheet-009021-4-en.pdf?n... http://sensing.honeywell.com/honeywell-sensing-hih4030-4031%20series-product-sheet-009021-4-en.pdf?n...
But I really don't know how much work is involved in this to get it working with Grove shield
Other candidates for Humidity sensors are the following (which I've got from https://software.intel.com/en-us/iot/hardware/sensors?field_component_type_tid=80540&field_component... IoT - Sensors, actuators, and shields to bring your project to life | Intel® Developer Zone):
https://software.intel.com/en-us/iot/hardware/sensors/am2315-temperature https://software.intel.com/en-us/iot/hardware/sensors/am2315-temperature
https://software.intel.com/en-us/iot/hardware/sensors/htu21d-temperature IoT - HTU21D Temperature | Intel® Developer Zone
https://software.intel.com/en-us/iot/hardware/sensors/veris-hdxxvxta-humidity-transmitter-family https://software.intel.com/en-us/iot/hardware/sensors/veris-hdxxvxta-humidity-transmitter-family
But again, for a me as a person with very light HW engineering skills, I don't know what's really involved in getting it to work.
Any help would be highly appreciated.
Thank you
