Intel® Makers
9881 Discussions
Humidity sensors compatible with Grove Shield
MIvan4
Hello there,
I'm looking for any humidity ( doesn't need to have humidity & temp) sensor that I can connect directly into the Seeedstudio Grove shield (that is attached to the intel edison arduino board). I've already read that the DHT11 / DHT22 has some issues and only a workaround exists (since I admit I'm not really technically-skilled to do any HW engineering / soldering / DYI work etc.,as I'm more into SW side of thing, this is not the right solution for me...)
I've read similar thread that suggested buying one of these:
http://sensing.honeywell.com/honeywell-sensing-hih4030-4031%20series-product-sheet-009021-4-en.pdf?n... http://sensing.honeywell.com/honeywell-sensing-hih4030-4031%20series-product-sheet-009021-4-en.pdf?n...
But I really don't know how much work is involved in this to get it working with Grove shield
Other candidates for Humidity sensors are the following (which I've got from https://software.intel.com/en-us/iot/hardware/sensors?field_component_type_tid=80540&field_component... IoT - Sensors, actuators, and shields to bring your project to life | Intel® Developer Zone):
https://software.intel.com/en-us/iot/hardware/sensors/am2315-temperature https://software.intel.com/en-us/iot/hardware/sensors/am2315-temperature
https://software.intel.com/en-us/iot/hardware/sensors/htu21d-temperature IoT - HTU21D Temperature | Intel® Developer Zone
https://software.intel.com/en-us/iot/hardware/sensors/veris-hdxxvxta-humidity-transmitter-family https://software.intel.com/en-us/iot/hardware/sensors/veris-hdxxvxta-humidity-transmitter-family
But again, for a me as a person with very light HW engineering skills, I don't know what's really involved in getting it to work.
Any help would be highly appreciated.
Thank you
Sergio_A_Intel
I'd suggest you to look at the Edison Shield testing report here https://downloadcenter.intel.com/download/24342/Intel-Edison-Galileo-Galileo-Gen-2-Shield-Testing-Re... Download Intel Edison, Galileo & Galileo Gen 2 Shield Testing Report .
This guide has the shields that have been tested with the Galileo and Edison board. For each sensor you can see general information of the sensor, hardware summary, links to datasheets, connection diagrams and code. This guide can be helpful since it shows which pins need to connected to the board, thus making the hardware connections part of the project easier.
Another important link to check out is this one http://iotdk.intel.com/docs/master/upm/modules.html upm: UPM Libraries . This is a list of the supported sensors. Each link also comes with a description of the sensor and code.
Sergio
MIvan4
Hi Sergio,
thank you for your answer. I actually did have a look at the Edison shield testing report, unfortunately there are no humidity sensors mentioned in the document.It's also quite outdated (last update from October 2014).
I decided to go with the HTU21D. However, I see that it's inevitable to do the soldering / attaching the HTU21D breakout to the breadboard...
As I'm really new to all this, would you recommend any soldering kit? I'm probably out of topic here, it's just any help would be highly appreciated.
I'm gonna buy the following:
http://www.amazon.co.uk/gp/product/B00OKJFLWO?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=AUN0JK... http://www.amazon.co.uk/gp/product/B00OKJFLWO?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=AUN0JK...
http://www.ebay.co.uk/itm/191106267139 http://www.ebay.co.uk/itm/191106267139
http://www.ebay.co.uk/itm/281200991638 http://www.ebay.co.uk/itm/281200991638
Then hopefully I'll be able to solder the header onto the PCB of the sensor. What's daunting me is the breadboard. According to the following demonstration, 2 pins are using row J on the breadboard and the other 2 pins use row I. Is it just for aesthetic reasons and can I plug all 4pins to just one row, e.g. row J?
https://cdn.sparkfun.com/assets/learn_tutorials/1/4/3/Hookup_bb.png https://cdn.sparkfun.com/assets/learn_tutorials/1/4/3/Hookup_bb.png
I plan on attaching the other end of the wires to the grove shield directly.
g3jza
Sergio_A_Intel
Yes, that is for aesthetics and help the person watching the diagram have an easier understanding of the circuit. In a breadboard you can have all the cables in the column J. You'd just have to move the black and blue cable one column to the left.
It'd be something like this:
Red: Row 14 column J
Black: Row 13 column J
Green: Row 12 column J
Blue: Row 11 column J
If you need a wider understanding of how to use a breadboard you can check https://learn.sparkfun.com/tutorials/how-to-use-a-breadboard How to Use a Breadboard - learn.sparkfun.com
Sergio
