Community
cancel
Showing results for
Search instead for
Did you mean:
MYoon1
Hypervisor for Edison?
Hi everyone,
Has anyone tried running hypervisor on Edison? I am looking for a way to run two OSes (two VMs) on Edison. If there is no way to run hypervisor on it, I would be also interested in running Linux on one core and a bare-metal application on the other, if this is possible. I would appreciate any information/suggestion. Thank you.
Tags (1)
Sergio_A_Intel
Hi mkyoon,
I'm not sure if it's possible to run hypervision on Edison. I'll do some research and let you know what I find out. If you decide to try it out let us know your results and post them on this thread. Regarding the bare-metal programming I've found a link you might find useful. It is for galileo but it might work on the Edison as well /message/220383 https://communities.intel.com/message/220383 .
Sergio
MYoon1
Thank you very much! Any information about working hypervisor configuration (if exists!) on Edison would be really helpful. I will post what I found as well. Thank you.
hyang22
Xen has a subproject that provide xen hypervisor for embeded enviroment, but I don't think there is a usable version for edison
Sergio_A_Intel
It should work, it might be slow but we do not have support for this.
Sergio
Matthias_H_Intel
Intel_Alvarado how do you mean "should work"? I guess u-boot would need to enable VT-X ... in order to use virtualization. Is what you say that virtualization is enabled?
VT-X is not available so no h/w assisted hypervisor.
however it is possible to offline an Atom core on Edison/Linux. then by putting your baremetal app into physical memory and initiating a SIPI/2INIT IPI sequence it should be possible to jump to baremetal app. You may look at https://github.com/izard/RTBench/tree/master/tools/src/baremetal RTBench/tools/src/baremetal at master · izard/RTBench · GitHub as a base, but some adjustments with addresses will be required.
Sergio_A_Intel
mhahn
VT-X is not enabled, but there is nothing stopping virtualization from happening on the software level.
Sergio
Matthias_H_Intel
Intel_Alvarado
apart from that the performance would be low compared to what it could be?
MYoon1
I was able to run qemu with --enable-kvm option on Edison. Doesn't this mean that VTx is enabled on Edison?
Sergio_A_Intel
As stated in previous post, VT-X is not enabled.
Sergio
