I am attempting to flash the "1-502_droidboot_and_firmware.xml" into my DELL Venue 8 7840.
Who can tell me reason about those Errors!!!
Thanks for your Help!!!
06/20/16 22:55:04.716 INFO : [Port 2/1] Start flashing the flash configuration with dnx_fw start state for 54D00TJA01
06/20/16 22:55:04.717 ERROR : Automatic reboot is not supported on this device, please reboot the device manually
06/20/16 22:55:04.717 INFO : [Port 2/1] Starting flash ...
06/20/16 22:55:04.717 INFO : [Port 2/1] Running `"C:\Program Files (x86)\Intel\Platform Flash Tool Lite\xfstkFlashTool.exe" "-1" "F:\ChromeDownload\venue_7840_droidboots\dnx_fwr_blackburn_qs_rd_opensource.bin" "F:\ChromeDownload\venue_7840_droidboots\ifwi_blackburn_qs_rd_opensource.bin" "" "F:\ChromeDownload\venue_7840_droidboots\droidboot_dnx.img" "0x80000c27" "none" "none" "0"` command
06/20/16 22:55:04.944 INFO : [Port 2/1] Disabling xFSTK Misc DnX
06/20/16 22:55:04.944 INFO : [Port 2/1] Disabling xFSTK wipe out ifwi option
06/20/16 22:55:04.944 INFO : [Port 2/1] Using xFSTK Solo interface (new API)
06/20/16 22:55:04.944 INFO : [Port 2/1] xFSTK Soft Fuse not set
06/20/16 22:55:04.944 INFO : [Port 2/1] XFSTK Downloader API 1.8.1
06/20/16 22:55:04.944 INFO : [Port 2/1] Copyright (c) 2015 Intel Corporation
06/20/16 22:55:04.944 INFO : [Port 2/1] fwdnx -- F:\ChromeDownload\venue_7840_droidboots\dnx_fwr_blackburn_qs_rd_opensource.bin
06/20/16 22:55:04.944 INFO : [Port 2/1] fwimage -- F:\ChromeDownload\venue_7840_droidboots\ifwi_blackburn_qs_rd_opensource.bin
06/20/16 22:55:04.944 INFO : [Port 2/1] osdnx --
06/20/16 22:55:04.944 INFO : [Port 2/1] osimage -- F:\ChromeDownload\venue_7840_droidboots\droidboot_dnx.img
06/20/16 22:55:04.944 INFO : [Port 2/1] gpflags -- 0x80000c27
06/20/16 22:55:04.944 INFO : [Port 2/1] softfuse --
06/20/16 22:55:04.974 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 0
06/20/16 22:55:06.104 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 1
06/20/16 22:55:07.234 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 2
06/20/16 22:55:08.364 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 3
06/20/16 22:55:08.994 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 4
06/20/16 22:55:10.124 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 5
06/20/16 22:55:11.254 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 6
06/20/16 22:55:12.384 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 7
06/20/16 22:55:13.014 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 8
06/20/16 22:55:14.144 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 9
06/20/16 22:55:15.274 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 10
06/20/16 22:55:16.404 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 11
06/20/16 22:55:17.034 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 12
06/20/16 22:55:18.164 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 13
06/20/16 22:55:19.294 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 14
06/20/16 22:55:20.424 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 15
06/20/16 22:55:21.056 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 16
06/20/16 22:55:22.186 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 17
06/20/16 22:55:23.316 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 18
06/20/16 22:55:24.446 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 19
06/20/16 22:55:25.076 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 20
06/20/16 22:55:26.206 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 21
06/20/16 22:55:27.336 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 22
06/20/16 22:55:27.966 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 23
06/20/16 22:55:29.096 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 24
06/20/16 22:55:30.226 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 25
06/20/16 22:55:31.356 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 26
06/20/16 22:55:31.986 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 27
06/20/16 22:55:33.116 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 28
06/20/16 22:55:34.246 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 29
06/20/16 22:55:35.376 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 30
06/20/16 22:55:36.006 INFO : [Port 2/1] XFSTK-STATUS--Detecting Intel Device - Attempt # 31
<span...
Hi Hysian,
I checked the full log, it seems that the Flash Tool Lite is not recognizing the device, I found similar issues in other forums where the solutions are to full charge the device or to unplug and plug the device.
I highly suggest you to contact forums like:
https://communities.intel.com/thread/67277 https://communities.intel.com/thread/67277
http://forum.xda-developers.com/lenovo-k900/general/lenovo-k900-discussion-views-google-app-t2256075...
Are you following one of the following tutorials?
http://www.gizmoadvices.com/root-dell-venue-8/
http://rootmygalaxy.net/how-to-root-dell-venue-8-7840-on-android-5-1-lollipop/
Due to his issue is more related to the device and Android I suggest you to contact forums for xda/android developers; they could help you with this issue.
Charlie
Hi Hysian,
Charlie
