I create a (bzimage/grub/ext/efi ...) with yocto,
ways follow :
./setup.sh
source ./iot-devkit-init-build-env yocto_build
bitbake image-full
put these into sd,then boot galileo ,
there are a lot of messy code come out ,the location is
[grub]
address=0xff800000
item_file=../../meta-clanton/yocto_build/tmp/deploy/image-spi-galileo/grub.efi
sign=yes
fvwrap=yes
guid=B43BD3E1-64D1-4744-9394-D0E1C4DE8C87
type=mfh.bootloader_signed
svn_index=4
[Linux-EFI, setup=0x10bb, size=0x1e0b00]
[Initrd, addr=0xd7d0000, size=0x19da5c]
......(all messy code)
I want to ask guys ,there are some configs I forget before I run "bitbake image-full" ?
grub.conf:
default 2
timeout 5
color white/blue white/cyan
title Quark X1000 kernel-SPI initrd-SPI IMR-On IO-APIC/HPET NoEMU
kernel --spi root=/dev/ram0 console=ttyS1,115200n8 earlycon=uart8250,mmio32,$EARLY_CON_ADDR_REPLACE,115200n8 reboot=efi,warm apic=debug rw
initrd --spi
title Quark X1000 kernel-MassStorage iot-devkit on SD IMR-On IO-APIC/HPET NoEMU debug
root (hd0,0)
kernel /bzImage root=/dev/mmcblk0p2 rootwait console=ttyS1,115200n8 earlycon=uart8250,mmio32,$EARLY_CON_ADDR_REPLACE,115200n8 reboot=efi,warm apic=debug rw LABEL=boot debugshell=5
title Quark X1000 kernel-MassStorage initrd-MassStorage RootFS-MassStorage IMR-On IO-APIC/HPET NoEMU debug
root (hd0,0)
kernel /bzImage root=/dev/ram0 console=ttyS1,115200n8 earlycon=uart8250,mmio32,$EARLY_CON_ADDR_REPLACE,115200n8 reboot=efi,warm apic=debug rw LABEL=boot debugshell=5 rootimage=image-full-quark.ext3
initrd /core-image-minimal-initramfs-quark.cpio.gz
I solve my problem! It's a nice day!
