Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
I cannot seem to get to the BIOS, when I press F2, the countdown stops and it boots immediately.
Jump to solution
Hi guys, I have no idea what's going on, I'm pressing F2, fn+F2, different keyboard, ubuntu 14.04 on Lenovo and Mac. Thoughts?
Joseph_B_Intel
levi_memsql, here is a hack that worked for me:
If you physically connect a keyboard up and hit F2, then you can get into the BIOS (while connected over a serial terminal), I just hit F2 several times until it came up.
Community Manager
Hi levi_memsql,
Did you try to flash your BIOS first? I would suggest to first complete that process and then try to access the BIOS again, you can find the instructions here https://software.intel.com/en-us/flashing-the-bios-on-joule https://software.intel.com/en-us/flashing-the-bios-on-joule. Right now, the document is written for Windows host computers only so take that into account.
Also, which baud rate are you using?
-Pablo
Community Manager
Hi levi_memsql,
I would also recommend to take a look at this guide about Setting up a serial communication for Windows hosts, /thread/105513 https://communities.intel.com/thread/105513. Make sure that your Putty configuration is correct, both for the session and for the keyboard.
-Pablo
Joseph_B_Intel
Try these putty settings (in Windows)
source: https://software.intel.com/en-us/node/672106 https://software.intel.com/en-us/node/672106
(I think this was the URL you were trying to refer to Pablo)
Joseph_B_Intel
Community Manager
Thanks, that worked. I'm glad I didn't have to install Windows. My least favorite solution is to use a different OS.
Joseph_B_Intel
cool! Glad I could help. Yah, using a different OS is a pain....
