Intel® Makers
9881 Discussions
I have Intel Compute Stick upgraded to Windows 10 want to create Recovery Disk but always get message SOME FILES ARE MISSING can't create Recovery Disk?
ZGila
Please help me in this regard.
I also run Sfc /scannow command it also gives the message some foles are corrupt and can't be repaired.
Please somebody help me in this regard. I am desprate to create Windows !0 Home Recover Disk.
Amy_C_Intel
Hello Zahidgilani,
Please try the following:
Update the Intel® Compute Stick BIOS; please download the latest BIOS version for this unit at: https://downloadcenter.intel.com/download/25506/BIOS-Update-FCBYT10H-86A- Download BIOS Update [FCBYT10H.86A]. I recommend doing a BIOS recovery and you can follow the steps at: http://www.intel.com/support/motherboards/desktop/sb/CS-035445.htm Intel® Compute Stick — BIOS Recovery Instructions.
If the issue persists try the following:
Roll back to Windows® 8.1, go to http://www.intel.com/support/motherboards/desktop/stck1a32wfc/sb/CS-035724.htm Intel® Compute Stick STCK1A32WFC — Windows® 10 Upgrade Instructions, scroll down to the tab "Recovery options after the upgrade" follow those instructions. Once you rolled back to Windows 8.1 follow the steps on the above link to upgrade to Windows® 10.
Amy.
