Intel® Makers
9881 Discussions
I have bought a new intel edison arduino board after setting up i cant able to communicate with putty
Community Manager
I have bought a new intel edison arduino kit after completing all the setting up process i cant able to communicate with putty software.
Community Manager
Could you provide some more details on how you have your Arduino Breakout board hooked up to your PC? Sharing a picture would be great as well.
Also, what Edison devices to see listed in your PC's Device Manager (Start->Run->'devmgmt.msc') when connected? Take a look under "Ports (COM & LPT)". You're looking for a 'USB Serial Port (COMx)' and you want to tell Putty to use 'Connection Type: Serial' , 'Serial line: COMx' at 'Speed: 115200'.
Community Manager
Hi Arun0303,
Thank you for contacting us.
That's weird. Did you try to flash your Edison? If you aren't please follow this guide:
After you have flashed it, please try to update the USB serial driver (the latest): http://www.ftdichip.com/Drivers/D2XX.htm http://www.ftdichip.com/Drivers/D2XX.htm
Then try to connect your Edison to putty using this guide: https://software.intel.com/en-us/setting-up-serial-terminal-on-system-with-windows IoT - Setting up a serial terminal on a system with Windows* | Intel® Software
If you still have issues, could you please send us a photo of your Device Manager? Or try it with a different USB cable.
I hope you find this information helpful.
Have a nice day.
Leonardo R.
Community Manager
I have flashed and completed all the process mentioned below.
Community Manager
If i click putty open i am getting a blank terminal window. After that i have pressed enter button twice but no response from putty
Community Manager
Hi Arun0303,
We would like to investigate more about your issue. So, can you please submit a service ticket using this form? https://supporttickets.intel.com/?lang=en-US
Have a nice day.
Leonardo R.
