I've had experience with SPLat embedded controllers that encourage multitasking in programme design. Please read this before you provide me with an answer. http://www.splatco.com/32_processes_for_the_price_of_one.htm SPLat Controls - Embedded microcontroller multitasking in electronic controls
You may want to read this too. http://www.splatco.com/rtos_1.htm SPLat Controls - Embedded microcontroller RTOS cooperative and preemptive multitasking in electronic controls
Along with structured programming, multitasking provides a very powerful method of programming. Each task is an independent piece of code that can run on itself. In the example below, there are four independent programmes. We can have global variables to share data. Whenever a task goes into a timing phase, the task is switched to the next. If there is no timing phase in a task, YIELDTASK is placed at the beginning of the loop for obvious reasons. It will loop once and switch to the next task. When it receives the focus again, loop once and yield again.
I would like to be able to do the vary same thing with Arduino C with either Arduino IDE or VS Visual Micro.
Any ideas?
For example
Launchtask CheckEmergencyPushButton
Launchtask ControlTankTemp
Launchtask MonitorPushbuttons
Launchtask LCDDisplayUpdate
Runtasksforever
CheckEmergencyPushbutton
LoopCode here
ControlTankTemp
LoopCode here
MonitorPushbuttons
LoopCode here
LCDDisplayUpdate
LoopCode here
Hi Fred,
The Arduino IDE uploads one sketch and the board can remember it, it also saves the sketch before the latest one; you can find the sketches on /sketch with the names sketch.elf and sketch.elf.old
When you say:
Are you planning to run different .ino sketches at the same time? If this is the case you will have to upload them in different rounds so you can have all the sketches in one specific folder and then be able to run them at the same time. Is this what you want to do?
If you want to run different parts of code that are located inside the same .ino sketch I suggest you to use pthread, this should allow you to run different tasks at the same time.
You need to use # include
https://computing.llnl.gov/tutorials/pthreads/ POSIX Threads Programming
You can find the library in C:\Users\YourUser\AppData\Local\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0\core2-3...
Charlie
Thank you for your reply, CMata_Intel. Judging from your questions I assume you didn't read the links. If you did read the links, especially the first shorth one, you'd understand what I'm up to. Instead or writing a spaghetti string programme, I break it down to small bite size programmes and run then all in one file. It's almost like a sequencer with subroutines. The exception is in a sequencer, you will stay in the routine until the timing function times out. Or you have have to set an elaborate logic scheme to leave the subroutine and return every now and then.
With multitasking, the microprocessor is clocking so fast you get the impression that their running simultaneously. Much like when you have a number of programmes open and running on Windows 10 or Linux. Even a Mac. A takeoff in object programming. They are all self contained. If you need to change one, you don't have to worry about affecting the others. That's one terrific payoff right there.
Look at my example and look at pThread. Very straight forward. Very simple. You can disable one or more tasks by simply placing a comment character in front and the rest will work as happy as can be. By the way, SPLat has a feel like BASIC. By comparison, pThread if very complex to set up.
I was hoping that someone came up with an eloquent approach.
By the way, I know the gentleman who wrote the SPLat language and Multitasking. I'm trying to convince him to work a form of Multitasking out for Arduino C.
Oh, Charlie, I did read the second link. I wasn't very impressed. I guess I'm spoiled. Sorry.
Multitasking is easy in Linux, just check the fork function.
Let's go back to microcontrollers and Arduino.
Your example:
Runtasksforever
ControlTankTemp and LCDDisplayUpdate can be run sequentially in the main loop.
You want to constantly poll the state of the push buttons.
It's better to connect the push buttons to GPIO pins and generate interrupts when the user pushes on them. Then handle these interrupts in Arduino.
Hello Vincenze. About the example I used.... I simply threw something together. The idea was you take a long speghetti type programme and break it down into its verious components. It's like machine state mapping, with subroutines that can be treated as objects. Polling is like replacing a fuel injector with a carburetor. Interrupts only handle inputs and you are limited. Multitasking can handle anything. How would I use interrupts on LCD display, real time clock monitoring, timing functions, arithmetic computations and so on? Did you read my links?
The trouble, Vicenze, is I read everything there is and the closest I can get to Multitasking is pThreads. They're not eloquent. Have you writen Visual C or Basic? You design the interface and then code the objects. There the module you write code that loops, not event driven. In effect, you have multitasking. That's what I'm after.
Nobody wants multitasking on Arduino.
Arduino is intended for small, slow and cheap microcontrollers. Typically, they have less than 16kB of RAM.
When you connect an LED to a pin of a microcontroller and change the pin from LOW to HIGH, you want it to be done almost instantaneously. You don't want the microcontroller to wait 2 seconds while another thread reads the RTC and consumes all microcontroller power.
When one microcontroller can't process simultaneous tasks, you just add a second microcontroller that costs $2. The first microcontroller flashes the first LED, the second flashes the second LED.
Then you have the Edison that costs $50, but its Linux natively supports multiprocessing and multitasking. Then you can download a file in one process, read the RTC in the second, update the screen in the third. If you are not satisfied with Linux, install something else, but you'll have problems with drivers.
What can be easier than multiprocessing with fork() in Linux? Using pthreads has its benefits, but it's more complicated.
Example:
# include
int main(int argc, char **argv)
printf("--beginning of program\n");
int counter = 0;
if (pid == 0)
// child process
int i = 0;
for (; i < 5; ++i)
printf("child process: counter=%d\n", ++counter);
else if (pid > 0)
// parent process
int j = 0;
for (; j < 5; ++j)
printf("parent process: counter=%d\n", ++counter);
else
// fork failed
printf("fork() failed!\n");
return 1;
printf("--end of program--\n");
return 0;
You have something like 18 lines of code for two elements (assumed). My example used four lines of code for three element. And it's intuitive.
If I wasn't aware of this product, http://www.splatco.com/ec_p1.htm SPLat Controls - SPLat alternative to Arduino, I might agree with you. $21 gets you one.
I used to represent SPLat in USA and Canada. I'm retired and decided to play with Intel/Edison with the Arduino board and I programme the lot with Visual Studio 2015/Micro. It's lots of fun. But, I wish I could multitask as I can with EC1. I can also do this on their more sophisticated HMI430. But the thought that I can do this on EC1 without event lag as you identified above is amazing and a natural for simplified FSM programming.
About my silly programme: As one element of the programme waits for someone to push a button, it is running the flashing element and monitoring the water temperature control element all at the same time. And you don't notice a delay. The controller clocks so fast through the machine codes you simply don't notice it. As soon as you hit that push-button, Bingo. If I decide to skip with the Flash_The_Light element, I simply place a comment (; semi-colon) in front of Luanchtask Flash_The_Light. You can launch a task from within a task and kill it as well. You will note that the language is very much like BASIC but a bit more complex. You don't have libraries to include. I'm not trying to push the language, but I do wish to demonstrate how simple multitasking can be employed on a dirt cheap controller like EC1.
If you wish to see something cute, watch what I did with a automatic drink mixing machine. http://www.somabarkickstarter.com/ Somabar | Robotic Bartender for your Home This was the original proof of concept controller I put together for them. http://drinkdispenseremoteandroid.blogspot.com/ Drink Programme with Remote on Android You should be able to connect to this Blogger. There are three videos here. I need to control Bluetooth, Remote HMI on an Android using SimpleHMI, and the control itself. It would not have been possible without multitasking and I could have used that cheapie EC1. I used a CC18 OEM controller ($54) because of its robust I/Os. http://www.splatco.com/cc16p1.htm SPLat Controls - CC18 - Embedded PLC programmable logic controller
Vincenze, I understand where you're coming from but I'm asking you to think outside of the box. With the computing power available on the Intel/Edison processor, surely, we can come up with something akin to Multitask. Or is a small Australian company more savvy than Intel? And I've been told that certain Arduino micro-controllers can handle it. And whilst we're at it... wouldn't it be nice to have a version of SimpleHMI to use an Android phones for HMI applications via Bluetooth? http://www.splatco.com/simplehmi_p1.htm SPLat Controls - SimpleHMI - Free Android HMI app
My_Silly_Programme: ;This is an actual programme. It can be downloaded into a SPLat controller with their IDE. 27 lines of code including Multitasking.
Launchtask Pushbutton
Launchtask Flash_The_Light
Launchtask Keep_Water_Warm
RunTasksForever
WaitPushButton = 1 ; input
PushbuttonLight = 6 ;output
FlashingLight = 7 ;output
WaterThermoSwitch = 2 ;input
WaterHeater = 8 ;output
Pushbutton: ;This programme element will wait for someone to hit that button.
waiton WaitPushbutton
on PushbuttonLight
waitoff WaitPushbutton
off PushbuttonLight
goto Pushbutton
Flash_The_Light: ;This programme element will continuously run, flashing a light.
on FlashingLight
pause 1000 ;pause for 1 second
off FlashingLight
pause 1000
goto Flash_The_Light
Keep_Water_Warm: ;This will wait for heat demand from a water bath.
waiton WaterThermoSwitch
on WaterHeater
waitoff WaterThermoSwitch
off WaterHeater
goto Keep_Water_Warm
Hi Fred,
I would like to know if you have found another approach or if you started to try with pthread.
I've been searching but I've only found pthread as an option right now, did you find some other way?
Charlie
Hi Charlie,
Nope, I haven't. pthread is too heavy to deal with. It shouldn't have to be like that. Someone should be able to boil it down to something more manageable. Imagine having to go through similar steps just to print a line of text. By the way, you may be interested in a neat way to programme in finite state machine (FSM). https://www.google.com/search?q=finite+state+machine&oq=finite+state+machine&aqs=chrome..69i57j0l5.1... Definition FSM The man who came up with Multitasking and FSM programming is Mr. David Stonier-Gibson. If we had his Multitasking library function and this https://www.youtube.com/watch?v=uqwmMFCMx3k FSM Tabula for Arduino, we would take Intel/Edison and Arduino into a realm no hobby embedded controller has ever gone. Ideal for university courses and research. Someone should talk to the man. Have any ideas?
How about starting a design group here on pthread made easy?
Take Care,
Fred
