Community
cancel
Showing results for
Search instead for
Did you mean:
MMunz1
I'm not quite sure what to do anymore.
Before I get into this, my original post --> got locked so I sorry I couldn't get back to the 2 responses I got.
Anyway,
for Christmas this year I was given a breadboard which ended up giving me a new inspiration to get my Galileo working. So as seen here
I first start with nothing plugged in (having the micro sd card both in and out made no difference so I chose to leave it in in this example). I will plug the usb into my computer, and then the micro usb into the client port on the galileo.
Then I plug in the power and this is what happens next --> https://youtu.be/Oq-oCgKkKkM First steps of galileo - YouTube
This is a list of the tutorials I was using for help:
https://www.youtube.com/watch?v=zUZmWe8nrc4&feature=youtu.be Getting Started with the Galileo - YouTube
https://www.youtube.com/watch?v=yrRMomesBKM&t=342s Getting Started with Windows on the Intel Galileo - YouTube
https://software.intel.com/en-us/get-started-galileo-windows-step1# gen1 IoT - Step 1: Make a bootable micro SD card | Intel® Software
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-galileo-boards/000006416.html SD Card Setup and Sketch Persistent for Intel® Galileo Boards
This is a picture of what my micro sd currently contains after I set it up using the 4th link above.
When I try to run "Blink" using the Galileo compatible version of Arduino, I am given this error message:
Arduino: 1.6.13 (Windows 10), Board: "Intel® Galileo"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\laugh\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\laugh\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\laugh\Documents\Arduino\libraries -fqbn=Intel:i586:izmir_fd -vid-pid=0X8086_0XBABE -ide-version=10613 -build-path C:\Users\laugh\AppData\Local\Temp\arduino_build_545313 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.sketchUploader.path=C:\Users\laugh\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0 -prefs=runtime.tools.i586-poky-linux-uclibc.path=C:\Users\laugh\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\laugh\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\laugh\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\laugh\Documents\Arduino\libraries -fqbn=Intel:i586:izmir_fd -vid-pid=0X8086_0XBABE -ide-version=10613 -build-path C:\Users\laugh\AppData\Local\Temp\arduino_build_545313 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.sketchUploader.path=C:\Users\laugh\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0 -prefs=runtime.tools.i586-poky-linux-uclibc.path=C:\Users\laugh\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0 -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'izmir_fd' from platform in folder: C:\Users\laugh\AppData\Local\Arduino15\packages\Intel\hardware\i586\1.6.7+1.0
Using core 'arduino' from platform in folder: C:\Users\laugh\AppData\Local\Arduino15\packages\Intel\hardware\i586\1.6.7+1.0
Detecting libraries used...
"C:\Users\laugh\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-g++" -m32 -march=i586 "--sysroot=C:\Users\laugh\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0/i586-poky-linux-uclibc" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -D__ARDUINO_X86__ -Xassembler -mquark-strip-lock=yes -w -x c++ -E -CC -march=i586 -m32 -DARDUINO=10613 "-IC:\Users\laugh\AppData\Local\Arduino15\packages\Intel\hardware\i586\1.6.7+1.0\cores\arduino" "-IC:\Users\laugh\AppData\Local\Arduino15\packages\Intel\hardware\i586\1.6.7+1.0\variants\galileo_fab_d" "C:\Users\laugh\AppData\Local\Temp\arduino_build_545313\sketch\Blink.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\laugh\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-g++" -m32 -march=i586 "--sysroot=C:\Users\laugh\AppData\Local\Arduino15\packages\Intel\tools\i586-poky-linux-uclibc\1.6.2+1.0/i586-poky-linux-uclibc" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -D__ARDUINO_X86__ -Xassembler -mquark-strip-lock=yes -w -x c++ -E -CC -march=i586 -m32 -DARDUINO=10613 "-IC:\Use...
FTinetti
Honored Contributor I
Hi BanjoBoy,
Without using the SD card (remove it and make the verification steps below without using the SD card at all) there are 2 problems, I think.
Problem 1: Compile an Arduino sketch example for Intel Galileo card. Please follow the step-by-guide starting at
https://software.intel.com/en-us/get-started-arduino-install IoT - Installing the Arduino* IDE | Intel® Software
Take into account how to use the Boards Manager option so that the Arduino IDE is able to compile sketches for Intel Galileo.
Regarding your first video,
if you are using win10, then there is nothing wrong in it, I've reported this behavior a few days ago:
(if you have trouble to get the .pdf with the sequence of steps please let me know)
And please make sure you select Intel Galileo card in the Arduino IDE before you compile. You can carry out all of the steps for compilation without an actual Intel Galileo. You'll need the Intel Galileo if you want to upload and run the Blink example, of course.
Problem 2: using the Intel Galileo serial interface. The video you posted:
BanjoBoy wrote:
Which I still don't know if works because I bought this other cable and this happened --> https://youtu.be/oN9gYtft0-o YouTube .
does not show anything wrong so far. Once you plug in your Intel Galileo card the OS does not have to open/do anything, it has already recognized you have plugged in a USB-to-serial device before, and that's it. You should use a program to open a terminal and connect to your Intel Galileo. I use PuTTY, as shown in thread
Once you are able to use your Intel Galileo we can go on the SD setting and usage, which is simple too.
HTH,
Fernando.
Community Manager
Hello BanjoBoy,
Thank you for interest in the Intel® Galileo Board.
I think you should try the suggestions provided by FGT (thank you very much for the support provided). Once you check those, please share your experience with the community in case you need further assistance.
Andres
