Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9868 Discussions
I think we need 2 images
MMoy
New Contributor II
I think it would be a good idea to have 2 images.
One for people who are using the Edison with the Arduino platform like you currently have, and another for those of us who don't plan to use it with Arduino and never intend to.
The purpose is to rip out anything Arduino related into the build.
Diego_V_Intel
Hi mikemoy,
That's sound interesting. I will pass it to the proper team so they can evaluate this idea. Thanks for the suggestion.
Diego.
DHunt5
Valued Contributor I
AFAIK, the only thing in the BSP that's Arduino related is clloader.
So delete the contents of /opt/edison, and the related init.d script
That's it.
MMoy
New Contributor II
That's it.
thanks for the tip, but still they should not produce a image for a product that is going to assume we are connected to another board of some kind.
Matthias_H_Intel
or just run "systemctl disable clloader" which will disable the clloader server for next boot but not delete it (the couple bytes remaining shouldn't harm)
PMart13
Valued Contributor II
I agree with mikemoy, it would be nice to have an image for those that use the edison with breakout board and non arduino/sketch users.
Matthias_H_Intel
What exactly should be the difference between those? If this would help one might consider adding Arduino enabling into the configure-edison script if directly putting "ifconfig disable clloader" into the console is viewed as too complex...
PMart13
Thanks mhahn for responding. At the risk of sounding too new, this is my first experience into the hardware side. I picked the edison and mini-breakout board for it's size, and powerful specs. I am impressed quite pleased with it's capabilities thus far, especially from a native on-board programmers view. So lacking that duino experience doesn't tell me what those differences are. There is tonnes of code that makes up everything, I've learned a lot from everyone on the forums, and what lacks in the code base - it's an Intel, I can create native language solutions. The tools are here, I have the source code to go through, I could bitbake or completely install my own kernel if desired. And everyone is here to help answer questions.
So no, it's not saying a disable command is too complex, or discovering the mini breakout has and extra i2c pair in mraa, or that it lacks an ADC that the Arduino board has, it is the not knowing, the learning curve, the time needed to pour through all that code to find all those differences.
A separate image might give mini-breakout the same jump start point as Arduino, but maybe discovery through all the code is half the fun.
