Community
cancel
Showing results for
Search instead for
Did you mean:
mcast11
I try to build edison but the URL appear to be down: 'http://download.xdk.intel.com/iot/xdk-daemon-0.1.4.tar.bz2
I try to build edison but the URL appear to be down: http://download.xdk.intel.com/iot/xdk-daemon-0.1.4.tar.bz2
Someone know where can I download this package?
Error log
WARNING: Failed to fetch URL http://download.xdk.intel.com/iot/xdk-daemon-0.1.4.tar.bz2, attempting MIRRORS if available
ERROR: Fetcher failure: Fetch command failed with exit code 4, output:
wget: unable to resolve host address 'download.xdk.intel.com'
ERROR: Function failed: Fetcher failure for URL: ' http://download.xdk.intel.com/iot/xdk-daemon-0.1.4.tar.bz2'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /media/matheus/Linus/edison/build_edison/tmp/work/core2-32-poky-linux/xdk-daemon/0.1.4-r0/temp/log.do_fetch.20239
ERROR: Task 1166 (/media/matheus/Linus/edison/build_edison/../poky/meta-intel-iot-devkit/recipes-devtools/xdk-daemon/xdk-daemon_0.1.4.bb, do_fetch) failed with exit code '1'
WARNING: Failed to fetch URL git://github.com/intel-iot-devkit/iotkit-comm-js.git;protocol=https, attempting MIRRORS if available
ERROR: Fetcher failure: Fetch command failed with exit code 128, output:
Cloning into bare repository '/media/matheus/Linus/edison/build_edison/downloads/git2/github.com.intel-iot-devkit.iotkit-comm-js.git'...
fatal: could not read Username for ' https://github.com': No such device or address
Octavian_C_Intel
Hello Matheus,
Thank you for your interest in the Intel Edison board.
The Intel® XDK is no longer being developed or updated for new operating systems and devices.
If you are building IoT applications, please check out Intel® System Studio and Arduino Create*.
You can download the Intel System studio from here: https://software.intel.com/en-us/system-studio/choose-download Choose & Download | Intel® System Studio | Intel® Software
Also, if you need more help setting up the Intel Edison here is the Getting started guide: https://software.intel.com/en-us/get-started-edison-windows-32 IoT
Hope this helps.
Octavian
Octavian_C_Intel
Hello Matheus,
Do you require any more assistance with this issue?
Octavian
