I try to connect my 2tb usb hdd but the stick hangs and I need to reinitiate.
Is it normal? I use an usb extensor. Is better a direct connection?
Do I have to connect the stick with the power supply instead of tv usb?
You should try using the original power adapter instead of tapping the power from the TV. The lack of power to the ICS can cause a lot of problems. This is definitely the first thing I will try.
Hello AmboStar,
Thank you for joining the Intel communities.
Did you try Choong recommendation?
Also, I would suggest to try with an active hub if what Choong recommended does not work.
Ivan
Thank you! I try Choong recomendation and it worked very good. It was a lack of power.
I'm glad that your issue has been resolved and thank you for letting us know about it.
Best wishes,
Ivan
