Community
cancel
Showing results for
Search instead for
Did you mean:
JHuds2
I2C Bus 6 Not Working on Intel Edison Arduino Breakout
Jump to solution
I am trying to build a quadcopter using the Edison- It has plenty of tech goodies to get the job done.
I have run into issues recently:
I need to interface with several devices that use I2C protocol. Reading through the datasheet for the Intel Edison Arduino Breakout; I found that the only available I2C bus is bus 6. The bus can be accessed through SDA/SCL or A4/A5. I wired up a Sparkfun accelerometer:
SparkFun Triple Axis Accelerometer Breakout - ADXL345
VCC >> 3V (From Edison Expansion Board)
VSS >> GND
SDA >> SDA
SCL >> SCL
(Also tied the pin that selects between SPI and I2C High)
The I ran the command i2cdetect -r -y 6. This is where everything went horribly wrong: I got a "YOU MAY CONFUSE THE SYSTEM" message. When I decided to move forward the Edison started printing the address table really slow! I tried a billion and one times to figure it out!!!
I'm starting to pull my hair out!
Help would be appreciated!
Pedro_M_Intel
Hello JBTheMan,
These are the commands I entered to set up the I2C interface on my Edison + Mini Breakout board:
echo 28 > /sys/class/gpio/export
echo 27 > /sys/class/gpio/export
echo mode1 > /sys/kernel/debug/gpio_debug/gpio28/current_pinmux
echo mode1 > /sys/kernel/debug/gpio_debug/gpio27/current_pinmux
If I try to run the "i2cdetect -r -y 6" command before I entered them I get a bunch of error messages but after everything seems to be working fine. Did you set up I2C this way? Does it make a difference?
Peter.
Pedro_M_Intel
Hello JBTheMan,
Peter.
JHuds2
I will give it a try and then get back to you...
