Intel® Makers
9881 Discussions
I2C LCD Runtime error
BKish
Currently I am using laterst image of Yocto (201606061707). Earlier I was able to use Grove RGB i2c lcd (Jhd1313m1) quite easily. After upgrading to the latest version, compiling the same python throws a runtime error. Can you help me sort this issue out please?
Here's the error,
Traceback (most recent call last):
File "LCD.py", line 5, in
myLcd = pyupm_i2clcd.Jhd1313m1(1,0x3E,0x62)
File "/usr/lib/python2.7/site-packages/pyupm_i2clcd.py", line 560, in __init__
this = _pyupm_i2clcd.new_Jhd1313m1(bus, lcdAddress, rgbAddress)
RuntimeError: UPM Runtime Error: upm::Jhd1313m1::Jhd1313m1(int, int, int): Unable to initialise the LCD controller
Here's the program
# import essential libraries
import pyupm_i2clcd as lcd
import time
# declare pins and initiate the device
myLcd = lcd.Jhd1313m1(0,0x3E,0x62)
myLcd.setCursor(0,0)
# RGB red
# myLcd.setColor(255,204,0)
while True:
for i in range(0,255,5):
myLcd.setColor(i,i/5,i/15)
myLcd.scroll(True)
myLcd.write('Third One')
myLcd.setCursor(1,0)
myLcd.write('LCD On')
time.sleep(1)
myLcd.write('LCD Off')
time.sleep(1)
myLcd.clear()
Community Manager
Hi Bhanukishan,
Thank you for contacting us.
First of all, make sure that you are using the latest Edison Image version (201606081705), you can download it from here: https://software.intel.com/en-us/iot/hardware/edison/downloads.
Now, about your issue, it is weird because I tried your code (with some changes) and it worked without issues. First I tested the UPM example and it worked ( https://github.com/intel-iot-devkit/upm/blob/f8663c90f3474a97175cd4ffcb35b190438df39b/examples/pytho...). Then I did the same with your code, but I got some errors with the line "import pyupm_i2clcd as lcd" and I changed it for "from upm import pyupm_i2clcd as lcd" using the example gave before as reference, after I did this change it worked.
About the error message that you have, I get that error message when the LCD display is not connected, so please make sure that your LCD display is connected before running the code.
I hope you find this information useful.
Have a nice day.
Leonardo R.
Community Manager
Hi Bhanukishan,
Have a nice day.
Leonardo R.
Community Manager
Hi Bhanukishan,
That's great, thank you for letting us know that it worked.
And Joe, the version of the image that you downloaded is: 201606081705, you can check it with the command cat /etc/version.
Leonardo R.
Community Manager
Thanks for an alternative approach to getting the version name people like to refer to here. I've reflashed my unit many times, so maybe I am mixed up, but I'm seeing:
root@edison:~# cat /etc/version
201606061707
root@edison:~# uname -a
Linux edison 3.10.98-poky-edison+ # 1 SMP PREEMPT Mon Jun 6 14:32:08 PDT 2016 i686 GNU/Linux
On my PC I do have Edison\Images\iot-devkit-prof-dev-image-edison-20160606-patch folder with the .bin files, I thought I last flashed that one. But if you're saying that image version should read 201606081705, then maybe I have installed the firmware from the Windows Edison Setup (file intel_edison_setup_win_v2016.2.007.exe) from https://software.intel.com/en-us/iot/hardware/edison/downloads Downloads for Intel® Edison Module | IoT | Intel® Software ? Would that explain it?
Community Manager
Hi Joe,
Yes, you are right. If you are using Intel Edison Board Configuration Tool (file intel_edison_setup_win_v2016.2.007.exe), when you are going to flash the firmware you can choose the option "Use existing image, located at:" and use iot-devkit-prof-dev-image-edison-20160606-patch, that should install the version 201606081705.
If you choose the option "Download and use the latest image", it will download the version 201606061707. Thank you for letting us know, I will inform this to the proper team.
Have a nice day.
Leonardo R.
Community Manager
Last question about this, I promise
Do you have release notes from the latest build (iot-devkit-prof-dev-image-edison-20160606-patch / 201606081705)? What is the '-patch' that required the build 2 days later...thanks..
Community Manager
Hi Joe,
The release notes are the same: https://software.intel.com/en-us/blogs/2016/06/06/intel-iot-dev-kit-35-release-announcement, it is the same image (3.5) with some minor changes, that's why it has the same release notes.
Have a nice day.
Leonardo R.
Community Manager
Thanks. Hopefully nobody is chasing issues down that happens on one of those builds but not the other - we wouldn't have any idea of what 'minor changes' were included I'm familiar with the SW release game, so I understand why this is the team's approach.
BKish
Thanks Leonardo. It worked.
