Community
cancel
Showing results for
Search instead for
Did you mean:
JArau
ID Intel Problems
I activate the intel edison, and afterward change the ID of the device, now I cant see the device (In the Cloud analytics) nor activate it with the new ID. When I try to activate it I get an error METADA, which I am not sure what it means.
What should I do?
Thank you in advance
Community Manager
I believe this is expected, if you take a look at section 2.3.1 of https://raw.githubusercontent.com/wiki/enableiot/iotkit-agent/IoT_Developer_Kit_Guide_to_Using_Intel... https://raw.githubusercontent.com/wiki/enableiot/iotkit-agent/IoT_Developer_Kit_Guide_to_Using_Intel...
"The device ID should not be changed after activation."
Can you post the complete error you're receiving? Have you tried to restart the agent?
Sergio
JArau
Yes, it was a big mistake from my part. I already reset it to the default ID device and clear the activation code, but when trying to activate again I get the following error:
I flashed with the new image and I get this: it looks a little bit different from the older version.
Community Manager
Yes, flash your Edison to the newest image. Try with some of the options of the iotkit-admin to try and make the agent work again such as reset-components, clear-device-id, reset-code.
Sergio
Community Manager
Were you able to flash your Edison with the newest image? What were the results of using the commands we recommended?
Sergio
