Intel® Makers
9872 Discussions
IO18/IO19 for I2C Connectivity ERROR
Community Manager
I am configuring Intel Edison with Arduino Breakout Board to establish I2C connection with GY-87 (http://goo.gl/lDW0TL GY 87 10DOF MPU6050 HMC5883L BMP180 Sensor Module New | eBay ) through a shift level (http://goo.gl/7yXVND 5pcs IIC I2C Logic Level Converter Bi Directional Module 5V to 3 3V for Arduino | eBay ).
GY-87, breakout board with the following chips:
  1. MPU6050 - Accelerometer + Gyroscope
  2. BMP180 - Barometer + Thermometer
  3. HMC5883L - Compass
I used the instructions of Hardware Guide of Intel Edison Kit for Arduino on 11.6, page 29 to enable the communication.
The electrical connection tried was:
1. Pins A4 and A5.
2. Digital pins SCL and SDA.
After configuring I tried to scan the I2C using i2cdetect command which I receive the following results:
root@test:/# i2cdetect -y -r 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: UU UU UU UU -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@test:/# i2cdetect -y -r 6
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
What should be the next steps to debug this?
Community Manager
Hi Robbiot,
Thanks for the information provided and we'll try to help.
According to the instructions in the Hardware Guide of Intel® Edison kit for Arduino (page 29) that you followed, could you please check if the changes are made when you ran these commands? (You can use the cat command)
# echo low > /sys/class/gpio/gpio214/direction
# echo high > /sys/class/gpio/gpio204/direction
# echo high > /sys/class/gpio/gpio205/direction
# echo in > /sys/class/gpio/gpio14/direction
# echo in > /sys/class/gpio/gpio165/direction
# echo low > /sys/class/gpio/gpio236/direction
# echo low > /sys/class/gpio/gpio237/direction
# echo in > /sys/class/gpio/gpio212/direction
# echo in > /sys/class/gpio/gpio213/direction
# echo mode1 > /sys/kernel/debug/gpio_debug/gpio28/current_pinmux
# echo mode1 > /sys/kernel/debug/gpio_debug/gpio27/current_pinmux
# echo high > /sys/class/gpio/gpio214/direction
Please let us know if these changes were made. We'll be waiting.
Yermi
Community Manager
Just to add few more info:
  1. I tested the sensors in an I2C scanner and are working fine.
  2. I tested sensors with additional pull up resistors o 10k ohms. Failure to be detected.
Community Manager
Hi Robbiot,
I apologized for not being clearly enough in my previous post, what I tried to say was:
  1. Run the instructions in the Hardware Guide of Intel® Edison kit for Arduino exactly as they are (page 29).
  2. Use the command cat in the instruction that I posted. See picture below.
Note: This applies only to check the changes applied.
On the other hand, in the Intel Edison Arduino board, we need to use the I2C_6_ for connecting devices to I2C communication (A4/A5 – analog headers and SDA/SCL – digital header), the I2C_1_ is used for the Edison Arduino board internally and it isn't available, so in order to detect your device please use this i2cdetect -y -r 6.
Additionally, we would like to suggest this thread /message/276726# 276726 https://communities.intel.com/message/276726# 276726 where they discussed about the Edison I2C communication and shifter uses.
Hope this information helps, please let me know if you have any other questions.
-Yermi
Community Manager
Thanks for your support.
Follow the commands and its results, plus i2cdetect command that I used to check if detects:
root@RobbiotMasRob3:~# echo low > /sys/class/gpio/gpio214/direction
root@RobbiotMasRob3:~# echo high > /sys/class/gpio/gpio204/direction
root@RobbiotMasRob3:~# echo high > /sys/class/gpio/gpio205/direction
root@RobbiotMasRob3:~# echo in > /sys/class/gpio/gpio14/direction
-sh: /sys/class/gpio/gpio14/direction: No such file or directory
root@RobbiotMasRob3:~# echo in > /sys/class/gpio/gpio165/direction
-sh: /sys/class/gpio/gpio165/direction: No such file or directory
root@RobbiotMasRob3:~# echo low > /sys/class/gpio/gpio236/direction
-sh: /sys/class/gpio/gpio236/direction: No such file or directory
root@RobbiotMasRob3:~# echo low > /sys/class/gpio/gpio237/direction
-sh: /sys/class/gpio/gpio237/direction: No such file or directory
root@RobbiotMasRob3:~# echo in > /sys/class/gpio/gpio212/direction
root@RobbiotMasRob3:~# echo in > /sys/class/gpio/gpio213/direction
root@RobbiotMasRob3:~# echo mode1 > /sys/kernel/debug/gpio_debug/gpio28/current_ pinmux
root@RobbiotMasRob3:~# echo mode1 > /sys/kernel/debug/gpio_debug/gpio27/current_ pinmux
root@RobbiotMasRob3:~# echo high > /sys/class/gpio/gpio214/direction
root@RobbiotMasRob3:~# i2cdetect -y -r 1
Community Manager
I don't think is configuration. I change the sensor GY-87 by GY-291 (ADXL345) and works fine:
ARDUINO BREAKOUT:
root@RobbiotMasRob3:~# i2cdetect -y -r 6
50: -- -- -- 53 -- -- -- -- -- -- -- -- -- -- -- --
ARDUINO BREAKOUT MINI
root@RobbiotMasRob2:~# i2cdetect -y -r 1
As I tested the GY-87 module in an I2C scan and works fine the question is where is the problem?
How can I identify where is the problem?
Thanks again,
Community Manager
Hi Robbiot,
The GY-87 can work at 5V (VCC_IN pin) and at 3.3V, so I would like you to try this (without using a level shifter):
  1. Set up the jumper J8 at the default position (1-2)
  2. Set up the jumper J9 at the position 5V (1-2) and then connect the Edison 5V pin to your VCC_IN pin in the GY-87. Review if it is detected
  3. Set up the jumper J9 at the position 3.3V (2-3) and then connect the Edison 3.3V pin to your 3.3V pin in the GY-87. Review if it is detected
Position J8 and J9 (see picture)
Hope this helps. Let me know if you can detect your GY-87.
-Yermi
Community Manager
Hi Robibiot,
I would like to know if you've been able to try my suggestions. Please let me know if you have any questions.
-Yermi
Community Manager
Thanks Yermi,
I will try late this week.
thanks,
Community Manager
OK, please let me know your results or if you need help.
-Yermi
