Community
cancel
Showing results for
Search instead for
Did you mean:
GChic
IP traffic test with a Modem USB, any idea?
Hello, I've managed to connect a Modem in the USB port. I have to use it because we connect to a private net with our sim. I also need to ifconfig down wlan0 (WIFI) of the board because if I have a WIFI connection and I also have the modem, I try to make a ping and it uses WLAN0 connection I think.
I need to try doing some tests like IP transfer with this modem.
Any idea of how to do it?
I've thought in FTP but I can't make it. It says: No route to Host
Tags (3)
Community Manager
Hi gonzimalaga,
Thanks for reaching out.
Could you please provide more details regarding what you want to achieve? On the other hand, I found some information regarding the "No route to Host" error message that points to a network configuration problem, so I'd recommend you to check your network configuration (gateway, correct IP address, etc.).
Take a look at these links for more details:
-Yermi A.
Community Manager
Hi gonzimalaga,
Do you still need help in this case?
-Yermi A.
GChic
Hello, at the moment we changed the schedule so I think that in a few weeks I will have to do this
Community Manager
Great! I'd encourage you to share your results with the community after testing, as it can help other users as well.
-Yermi A.
