Community
cancel
Showing results for
Search instead for
Did you mean:
RTsou
ISSM_2016_2_090 flash subsystem problem: always "Launching : Configuring GDB"
Hi ALL:
I am using ISSM 2016_2_090 and Intel CRB doing some testing.
The ISSM Build information:
Intel® System Studio for MicrocontrollersVersion : 4.5.0.201703211802
After Update ROM to QMSI-v1.4, I can flash my project into C1000 main core, and the project BSP is QMSI-v1.4.
But, when I testing flash a simply project(Hello_World) into C1000 subsystem.
The ISSM always shows :
I wait for a long time(at lease 5 min), it doesn't stop. So, I can't flash project into subsystem.
I had check the CRB with old ISSM version. In old ISSM version, I could flash both and project could running.
And I also re-install ISSM, but the problem can't fix.
Could you please help check the problem?
Or provide any suggestion to me.
Thanks~
Michelle_C_Intel
Hi Ray ,
What OS are you using ?
Can you take a look at the OpenOCD Session in the Debug Perspective and let me know what you see there -- set the Log Level to 'Notice'.
-Michelle.
RTsou
Hi Michelle :
My OS is Win10.
The OpenOCD Session is below:
>>> Command: C:\IntelSWTools\ISSM_2016.2.090\tools\debugger\openocd\bin\openocd.exe -f scripts/board/quark_se_onboard.cfg -c set SEND_IDLE_ALIVE_BLIP 1 -c set QUARK_D2000_SHUTDOWN_ON_TAPSTATUS_FAIL 1
Open On-Chip Debugger 0.8.0-dev-gff947541-dirty (2017-03-14-22:03)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.sourceforge.net/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
adapter speed: 1000 kHz
trst_only separate trst_push_pull
jtag_ntrst_delay: 300
1
1
Info : clock speed 1000 kHz
Info : JTAG tap: quark_se.cltap tap/device found: 0x0e765013 (mfg: 0x009, part: 0xe765, ver: 0x0)
Enabling arc core tap
Info : JTAG tap: quark_se.arc-em enabled
Enabling quark core tap
Info : JTAG tap: quark_se.quark enabled
Processor type: arc-em
Info : accepting 'gdb' connection from 3334
undefined debug reason 7 - target needs reset
adapter speed: 4 kHz
redirect to PM, tapstatus=0x00300c1c
unknown break reason at 0x4003003e
target state: halted
target halted due to undefined at 0x4003003e in protected mode
target halted due to debug-request at 0x0000fff0 in real mode
force hard breakpoints
0x4002f008: 000028a0
0x4002f40c: 00000060
1576 bytes written at address 0x40000000
12 bytes written at address 0x40000628
downloaded 1588 bytes in 0.786499s (1.972 KiB/s)
0
'write' watchpoint 0 set at 0xa8000000 with length 4 (hwreg=0)
target running
Michelle_C_Intel
Hi Ray,
I think the issue is that the Application you have running on the Quark(x86) Core is not starting the ARC (Sensor Subsystem) Core.
With the latest version of the ROM the ARC is no longer started by the Bootloader and must instead be started by the Application running on the x86 core.
There is a sample application (under 'Applications' in the ISSM Create Project menu) that outlines what is required to have the x86 Application start the ARC ...
# include "qm_soc_regs.h"
# include "ss_init.h"
# include "power_states.h"
* Start the ARC Running.
* This example exemplifies how x86 applications may start ARC execution.
* When ENABLE_RESTORE_CONTEXT feature is enabled, the x86 needs to be ready
* to resume the ARC after sleep.
* To achieve this, the x86 core saves its context, and wait for ARC to trigger
* sleep. After wake-up, the x86 resumes execution where it stopped and
* resumes the ARC core.
int main(void)
# if (ENABLE_RESTORE_CONTEXT)
while (1) {
/* Start ARC. */
sensor_activation();
/* Wait for ARC to enter sleep. */
qm_power_sleep_wait();
# else
/* Start ARC. */
# endif
return 0;
-- Michelle.
RTsou
Hi Michelle :
Thanks for your answer.
After add "Start ARC", I could flash subsystem.
