Intel® Makers
9874 Discussions
ISSM_2016.2.094 New project Build Error
NHsie4
Hi, I download the "Intel® System Studio for Microcontrollers Update 2" for Windows* platform recently.
( reference : /thread/114358 https://communities.intel.com/thread/114358 )
There is the software environment
1
OS
Windows 8.1 64-bits
2
ISSM Version
ISSM_2016.2.094 (w_cembd_mv_p_1.0.2.094)
I create some new project for Intel Microcontrollers.
And click the Build button to compile project.
No.
SOC =
Target
APP_NAME
1
quark_se
x86
Hello_World
2
quark_se
x86
Quark_LED_Blink
3
quark_se
x86
<td style="border-top: none; border-left: none; border-bottom: solid windowtext 1.0pt; border-right: solid wi...
Michelle_C_Intel
It looks like you have a similar issue to this thread - which was a PATH problem --
Can you you try updating the PATH setting in the C:/IntelSWTools/ISSM_2016.2.094/issm_env.bat to below and restart ISSM. Let me know if this works.
:: Extend PATH with ISSM tools
set PATH=C:\WINDOWS\System32\Wbem
set PATH=%ISSM_UTILS_ROOT%;%ISSM_TOOLCHAIN_BIN%;%ISSM_TOOLCHAIN_UTILS%;%ISSM_TOOLS_ROOT%/python;%ISSM_TOOLS_ROOT%/python3;%DFU_UTILS%;%PATH%
-Michelle.
Michelle_C_Intel
-Michelle.
NHsie4
Dear Michelle :
The project in ISSM_2016.2.094 build successfully after set PATH:
My command prompt :
C:\Windows\system32>set PATH=C:\WINDOWS\System32\Wbem
C:\Windows\system32>set PATH=%ISSM_UTILS_ROOT%;%ISSM_TOOLCHAIN_BIN%;%ISSM_TOOLCHAIN_UTILS%;%ISSM_TOOLS_ROOT%/python;%ISSM_TOOLS_ROOT%/python3;%DFU_UTILS%;%PATH%
C:\Windows\system32>cd C:\IntelSWTools\ISSM_2016.2.094
C:\IntelSWTools\ISSM_2016.2.094>iss_mcu_ide_eclipse-launcher.bat
Copyright (C) 1985-2016 Intel Corporation. All rights reserved.
Intel(R) Compiler 2016.0 using LLVM technology (package 025)
It also works after edit C:\IntelSWTools\ISSM_2016.2.094\issm_env.bat
There is my final issm_env.bat :
@ECHO off
:: Copyright (c) 2016 Intel Corporation
:: General-purpose variables
:: Root directory for the installed ISSM
set ISSM_ROOT=%~dp0
:: Change backslashes to slahes
set "ISSM_ROOT=%ISSM_ROOT:\=/%"
:: Strip the trailing slash
set ISSM_ROOT=%ISSM_ROOT:~0,-1%
:: Root directory for the tools
set ISSM_TOOLS_ROOT=%ISSM_ROOT%/tools
:: Legacy variable
set ISSM_PATH=%ISSM_TOOLS_ROOT%
:: Root directory for the toolchain
set ISSM_TOOLCHAIN_ROOT=%ISSM_TOOLS_ROOT%/compiler/gcc-ia/5.2.1
set ISSM_TOOLCHAIN_GCC_IA_ROOT=%ISSM_TOOLCHAIN_ROOT%
set ISSM_TOOLCHAIN_GCC_ARC_ROOT=%ISSM_TOOLS_ROOT%/compiler/gcc-arc/4.8.5
set ISSM_TOOLCHAIN_LLVM_IA_ROOT=%ISSM_TOOLS_ROOT%/compiler_llvm/linux/
:: Binaries directory for the toolchain
set ISSM_TOOLCHAIN_BIN=%ISSM_TOOLCHAIN_ROOT%/bin
:: Prefix for toolchain binaries, ex. i586-intel-elfiamcu-gcc
set ISSM_TOOLCHAIN_PREFIX=i586-intel-elfiamcu-
:: Binutils for the toolchain, without prefix %ISSM_TOOLCHAIN_PREFIX%
set ISSM_TOOLCHAIN_UTILS=%ISSM_TOOLCHAIN_ROOT%/i586-intel-elfiamcu/bin/
:: GCC version
for /f %%i in ('%ISSM_TOOLCHAIN_BIN%/%ISSM_TOOLCHAIN_PREFIX%gcc -dumpversion') do set ISSM_TOOLCHAIN_GCC_VERSION=%%i
:: Debugger
set ISSM_DEBUGGER_ROOT=%ISSM_TOOLS_ROOT%/debugger
:: Utils
set ISSM_UTILS_ROOT=%ISSM_TOOLS_ROOT%/utils
:: Python
set PYTHONHOME=%ISSM_TOOLS_ROOT%/python
:: LLVM-based toolchain
IF EXIST %ISSM_TOOLCHAIN_LLVM_IA_ROOT%/bin/xcompilervars.bat (
call %ISSM_TOOLCHAIN_LLVM_IA_ROOT%/bin/xcompilervars.bat -platform mcu
:: DFU
set DFU_UTILS=%ISSM_TOOLS_ROOT%/dfu_utils/1.3
:: Application specific variables
:: BSP
set ISSM_BSP_ROOT=%ISSM_ROOT%/firmware/bsp/1.4.0
set IAMCU_TOOLCHAIN_DIR=%ISSM_TOOLCHAIN_GCC_IA_ROOT%/bin
set ARCMCU_TOOLCHAIN_DIR=%ISSM_TOOLCHAIN_GCC_ARC_ROOT%/bin
:: IPP
set IPPROOT=%ISSM_ROOT%/firmware/lib/ipp/1.2.0
set IPP_LIBRARY_PATH=%IPPROOT%
:: Zephyr
set ZEPHYR_GCC_VARIANT=issm
set ISSM_INSTALLATION_PATH=%ISSM_ROOT%
set ZEPHYR_BASE=%ISSM_ROOT%/firmware/zephyr/1.7.0
set MINGW_DIR=C:/mingw/msys/1.0
set ISSM_TOOLCHAIN_IA_SELECT="gcc"
set TINYCRYPT_SRC_DIR=%ISSM_ROOT%/firmware/lib/tinycrypt-0.2.6
:: Add 101 support by default
set ISSM_ENABLE_101_SUPPORT=1
NoSheng.
