Intel® Makers
9881 Discussions
ISSM for D1000 - OpenOCD Crash on Windows 7?
ABurn2
When using ISSM version ISSM_d1000_2015.3.024 on Windows 7 or Ubuntu 14.04
With D1000 CRB V3
Install goes fine, build code goes fine, until i debug and then openocd crashes when GDB connects to it on port 3333.
Tried running GDB automatically via Eclipse and also command line "target remote localhost:3333"
Printscreen of crash below (attached)
any known issues?
Included as an issue for D2000 incase its an issue there
cheers,
Adrian
bartosz.firmwaveavijit.M
also posted it here:
https://software.intel.com/en-us/forums/intel-system-studio-for-microcontrollers Intel® System Studio for Microcontrollers
ABurn2
more info here such as exact error and Eclipse version:
things worked ok on Linux with the same version of Eclipse and same debug configurations, so its some windoze problem, any ideas?
MuhamadSof_B_Intel
Hi Adrian,
Do you experience this issue intermittency? Or it always crash?
Soffi
ABurn2
Hi Soffi,
Always on Windows, never on Ubuntu. The problem is that half of our development team use Windows.
thanks,
Adrian
MuhamadSof_B_Intel
Hi Adrian,
Could I see your debug configuration?
Soffi
ABurn2
Hi Soffi,
see below.
thanks
avijit.M bartosz.firmwave
AMath11
Hi all,
It seems to be working on Eclipse Mars on Windows 10, maybe some version conflict?
ABurn2
Hi Avijit,
Worked ok for me on Windows 8 also with Eclipse Mars but on Windows 7 (even with Eclipse Mars). A fix is needed by Intel so Its not got to do with Eclipse version.
thanks
